Shiney Axle Swap ;)
Re: Shiney Axle Swap ;)
your gear box on your 2lte will fit 1kz
scott gibson
radar21 wrote:your gear box on your 2lte will fit 1kz
unfortunatly its auto aswell
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
So what's involved in getting this roadlegal?
Are certfied welders required for chassis and suspension welding or just inspected welds?
dont need to be certified welder they just look at ya welds..and aslong as theyre all g then no bother
if my surf had airbags then itd be more intense certification exercise.
ive got acouple more braces to put in just to beef it right up but as it is it world be strong enough.
after the new year the certifier is going to come check the suspension out and tell me anything i needa change but i cant see there being any issues.
Obviously it wont get certd until whatever engine i choose to use is out in at the moment its still got the 2lte
Ryan
Ryan
Its only leaving my shed with a 1KZ Ryan.....!!!
NJV6 wrote:Its only leaving my shed with a 1KZ Ryan.....!!!
.....so your saying i can do the engine swap in ya shed
youll notice ive put a few things beside my truck in ya shed man..including more tools
whats a good winch to go for?been reading up on a WARN 9000lb one cant remember the exact name but 6hp etc. sounds damn grunty to me? how good is the water proofing on warns? opinions one superwinch?
still cant decide on what engine!!
Ryan
Ryan
Engineer wrote:whats a good winch to go for?been reading up on a WARN 9000lb one cant remember the exact name but 6hp etc. sounds damn grunty to me? how good is the water proofing on warns? opinions one superwinch?
still cant decide on what engine!!![]()
Ryan
12000lb Milemarker Hydraulic,perfect for a club truck
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Jafa wrote:Engineer wrote:whats a good winch to go for?been reading up on a WARN 9000lb one cant remember the exact name but 6hp etc. sounds damn grunty to me? how good is the water proofing on warns? opinions one superwinch?
Ryan
12000lb Milemarker Hydraulic,perfect for a club truck![]()
milemarker aye..never heard of them. i have just started looking into building a hydro winch..doesnt seem that hard..i must be missing something!!
I would go the 1KZ... why manual?
Who knew Prados could fly?
decided to go with the commy, ive got everything i need for it..i know theyre a good torquey 4wd proven engine that can spin the wheels if need be with no fuel economy
on a side note got my CB in! startn to ease my way back into working on the damnd thing.
just wanna take it 4wdn
BRAKES
now my brakes have never been flash..one of the reasons is the master cylinder is bypassing and two well, its a surf..they dont have the BEST brakes around. now since ive got 35s and going commy i wanna be able to haul up when i want to so im havn a big spend up (again) to get te issues sorted.
1) new master cylinder, i do want to go disks on the rears so whats the story with getting a master cylinder wit proportioning valve? if i get calipers that are cable operated for the rear will i need the proportioning valve or stick with stock surf one or not?
2) new rotors, for the $$ is it worth buying slotted rotors? from the states theyre just over twice the price of stock ones here.
3) ill be going braided lines to try help eliminate the spongy feel rubber hose can give
4) i want grippy pads..seems you can only get two sorts..bendix and feredo (spelling) standard and the "4wd version" of each but there r heaps of different ones available ex the states. has anyone used the "4wd version" pads
thanks in advance for any comments
ryan
ryan
Mine stops great, even on 40's, I have an 80 series master cyl which is larger bore, and commodore front calipers on the back, cruiser discs on the front with IFS calipers. Dont buy slotted discs, do them yourself, your an engineer. Honestly I dunno whether the slots made any difference. We can supply braided line kits.
Jafa
Jafa
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Jafa wrote:Dont buy slotted discs, do them yourself, your an engineer.
im no longer in a machine shop n only have access to a midget hopeless lathe, im not doing them with a grinder
Jafa wrote:Mine stops great, even on 40's, I have an 80 series master cyl which is larger bore, and commodore front calipers on the back, cruiser discs on the front with IFS calipers. Dont buy slotted discs, do them yourself, your an engineer. Honestly I dunno whether the slots made any difference. We can supply braided line kits.
Jafa
80 series is bigger than 1" bore? does it have proportioning valve?
80 series rotors on the front?
what rotors have u got on the back?
what r the braided hoses worth from u?
thanks ryan
80 series is 1" and has residual valves, not proportioning valve
They are 40 series rotors DBA # 151 brand new are about $60 from Les Hunter Automotive in ChCh
Rear rotors are solid axle Hilux fronts
See page 1 and 2 of my build thread
braided lines are about $60 each
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Slotted rotors are only for better cleaning ability. They don't grip the pads any better than solid rotors do.
Vented rotors shed heat better, again they don't stop better when cold but take a whole lot more punishment before heating enough to fade.
right sorted...just bought some suby calipers for $25ea. so im going with new surf vented rotors on the front, suby calipers on the rear with hilux rotors and 80series master cylinder, braided lines and a good set of brake pads.
nothing new but hey its tried n true and resonably cheap.
that should stop me fairly good
getting front axle back together, new bearings and seals etc...once thats done and when i can be bothered ill be ready to rip the 2lte out.
Rocksliders..
Iv never had them before..whats the preferred method of mounting them, solid mount to chassis and build from there or have them removable?
opinions and a statement as to why would be the shiz
Thanks
Ryan
Rocksliders..
Thanks
Ryan
IMO bracket mount to the chassis. You can then exo (if required) off it and have no cert issues as it is all bolt on, and is a roof rack
- hosehustler
I had them removeable on my last truck........didn't ever remove them in about 4yrs
This time i've welded them to the chassis as I never intend to remove them, as you need cert anyway it's fine to weld them in place, if you intend to do a body lift make sure you do that first or they'll be too low
I hate signatures
hosehustler wrote:I had them removeable on my last truck........didn't ever remove them in about 4yrs![]()
yep done bodylift. i was thinking i was gunna weld them onto chassis as i couldnt see any need to remove them.
rokhound wrote:IMO bracket mount to the chassis. You can then exo (if required) off it and have no cert issues as it is all bolt on, and is a roof rack
what on earths IMO?
Ryan.
Engineer wrote:what on earths IMO?![]()
Ryan.
In My Opinion
well 2lte is long gone, finally got around to putting some gussets onto radius arm mounts so thats all done. removed efi wiring and the diesel stuff i wont require.
next stage is put marks adaptor onto the t700 trans and then put the engine in!
id like to have the adaptor on in the next two weeks
whether i get time/can bothered or not is different story
im not big on wiring and all that shet..is it worth spendn the $700 and getting marks adaptor kit...
Interface Wiring Loom (DIESEL) (Includes Tacho Interface)
Commodore V6 VN, VP and VR engine interface loom to suit Diesel models.
The Kit consists of: Wiring loom, special plugs, relays, sealed fuses and comprehensive instructions. The kit also includes a diesel tacho interface
Thanks
Ryan.
Thanks
Ryan.
wired up my this weekend so it was all turn off the key and cost me under $100 and took me 10 min
the tacho dose not work but will put the petorl dash in and hook it up , the marks loom kit is a good idea but I could not spend that much cash on something I can do myself
but it depends on what you want if you want to shag arround with the wiring or use a plug and play loom
Chopper01 wrote:wired up my this weekend so it was all turn off the key and cost me under $100 and took me 10 min![]()
crikey..are you able to write up what u done to get it going so easily an so cheap?
im good with spendn $ aslong as its done right but if its that easy then im sure i could handle it! im not completly useless wit wiring n shet i just hate it with a passion lol
hence.. me engineer steel *grunt* no sparky
yea only used two relays some wire and two fueses , there are two wires that go straight the + and there is one wire for the computer and another wire for the injectors that go through the relay , you will also have the fuel pump to wire up as well and the starter motor to wire up , plus the altinator but that has its own loom and is simple to wire in , is your adaptior the one that you need to strip down the auto to replace the main shaft , the adaptior I put in my rig was one of the ones Glen got me and I thought it was farken great so easy to put together
I will sit down and nut out the colours of the wires you need and write up a post in the next few days
Chopper01 wrote:yea only used two relays some wire and two fueses , there are two wires that go straight the + and there is one wire for the computer and another wire for the injectors that go through the relay , you will also have the fuel pump to wire up as well and the starter motor to wire up , plus the altinator but that has its own loom and is simple to wire in , is your adaptior the one that you need to strip down the auto to replace the main shaft , the adaptior I put in my rig was one of the ones Glen got me and I thought it was farken great so easy to put together![]()
thanks man! yes i have to replace the output shaft but all good something else to learn and say ive done
thatd be great if you can do a wee write up!
p.s thanks for that transfercase chop!!!
