Okay this work thing has been a real PIA (but after going down over $2m in the last 2 years, I will not complain that it is getting busy again
So any way, here's an update of some progress
Got a radiator shroud made up and fitted, It now has some fans attached as well
Shot of front guard which has been reshaped at the front, The axle is so far forward now that I don't have to even flatten the seam in the wheel arch which you normally have to do just to fit 33"s
Rear guard reshaped with new fuel filler in and exhaust exit flushed off
Painted all the door shuts and inner guards, and interior etc. This is a major job
Transmission oil cooler lines for the auto
Holden air con pump for OBA in. It is a sanden but not an SD unit, so I have fitted an oiler etc and we shall see how it goes I guess
It is getting quite full in here now, I have also put a power steer cooler in the front
Made up a steering column out of an IFS surf, beam axle surf and 70 series cruiser
My new (2nd hand) 120a alternator
Have a guess what has started now!
Relocated main fuse box and new frenched in box for extra fuses and relays
This is what is swallowing heaps of time, making all the clips etc to keep all the wiring and plumbing tidy and out of the way
I have chopped out a fair old chunk from here to allow for the snorkel to fit in between the inner and outer guard
Snorkel on and attached to the inner guard. I didn't want the snorkel attached to the A pillar so I can get the front clip off in one piece, complete with air filter.
And with outer guard on. I reckon it looks way better than having a fark off ugly pipe hanging on the outside
