darinz wrote:The biggest thing I think is your upper arms are too short! You should be aiming for 70% minimum of the lower links. The greater the travel the closer the lengths need to be.
The problem will be the pinion abgle change that may cause driveshaft problems. (depending on travel)
I'd cylce the calculator and see what sort of pinion change you get before you weld too much.
Thanks for the comments...
My top arms are 720mm long vs bottom arms are 1000mm - thats 72%. Do you mean they don't extent far enough down the chassis?
Articles I read stated top arms should be between 70-75% of the bottom arm lengths so at 72% I'm at the mid point.
Have checked my setup and it gives 'Pinion Change' at 0.00 degrees (listed in yellow box at top right hand side). Is this the best place to confirm this?
I'm not really following what you mean by the above comments ( not surprising really as only two days ago I had no idea how to use the calculator) - do you have any suggested changes? .
From the first lot of calculations listed I intend to:
1. Drop the diff mounts for the upper links approx 30mm. Makes top links flat.
2. Raise and move the lower link diff mounts to the front face of the housing (raises back of lower arms approx 60mm).
3. Drop the chassis mounts of the lower links 30mm.
These changes reduce Anti-squat to 79% - which should be better from what I'm being told.
Hopefully might get a bit more out of those adjustments but I expect AS to be between 70 - 79% once done. From what I can see I shouldn't have any major issues with that level of AS - correct?
