Wanted: Tidy 40 Series Cruiser
- ClassicCruiserSpares
- Sausage Shack
Re: Wanted: Tidy 40 Series Cruiser
That yellow 40 is a very tidy truck i know the guy selling it because i supplied him with parts for it when he was building up, hes a straight up guy he wont rip you off.
- cooksworld
Here's a mint looking stock one - http://www.trademe.co.nz/Trade-Me-Motor ... 690141.htm
Thats been on there for sooo long
would be interesting to have a look at tho
Didn't barbie drive a jeep??
This one looks pretty tidy too http://www.trademe.co.nz/Browse/Listing.aspx?id=322861344
- cooksworld
...or for one with a Lexus conversion http://www.trademe.co.nz/Trade-Me-Motor ... 812031.htm
top $ wanted and not sure if I actually like it... might just be the chrome rims
cooksworld wrote:...or for one with a Lexus conversion http://www.trademe.co.nz/Trade-Me-Motor ... 812031.htm
I would love a 1UZ Cruiser..
But not for 15k.
And not with those farkn awful wheels
Anyone got anything bad to say about this thing before I hand over the $$$ ?
http://www.trademe.co.nz/Browse/Listing.aspx?id=325183266
10k
Might be worth making sure that checker plate isn't just hiding something bad.
Not quite..
Id agree with the chequer plate hiding rust. They rust really bad round the sills an the rear of the tub where the panel braces are spot welded to the outer panels will probably have rust
- Sausage Shack
You could also find that the rust has been cut out from underneth the alloy and there will holes and the checker plate just covers over top, used to be the cool thing to once apon a time and there were heaps of cruisers with checker plate on them,but Imo i think it looks horrible and ruins the look of a 40.
- williamhamilton
smurf182 wrote:Anyone got anything bad to say about this thing before I hand over the $$$ ?
You can have mine for that price I would think
If none of the Welly crew can check it out I may be down in Tawa this weekend and happy to look and take pics.
W
- Beer_Cruiser
Ive had a look at this truck. It was 6 12 m ago and was very rusty. Seams to have been past around the local Indan auto commuity to be fixed up to make some money.
- flyingbrick
kinda sounds like he's bought it
Wuld be cool if it was kinda two tone.. with the bottom half all aluminum plate
I think its a nice looking truck.
Wonder if that aluminum is glued down. Could drill out the rivets and have a look easy enough. Rust kill or remove anything thats under there.
Apparently it's gone straight from the panel beaters where it got a few rust issues sorted to the WOF station where it's got a new warrent this month.
Don't worry theres no way I was gonna pay 10k for it.
It has a cage, small block Chev on LPG and 4 speed, power steering, new WOF, LVVC.
The only thing I really plan on doing to it is to assess the rust situation, and if that's all good then maybe a rear spring flip and disc brakes on the front.
Wish me luck !
Wish me luck !
smurf182 wrote:Apparently it's gone straight from the panel beaters where it got a few rust issues sorted to the WOF station where it's got a new warrent this month.
Don't worry theres no way I was gonna pay 10k for it.![]()
Wish me luck !
So does this mean.......the search is.......... over?
- Sausage Shack
smurf182 wrote: maybe a rear spring flip
Whats a rear spring flip? what does that do?
ClassicCruiserSpares wrote:smurf182 wrote: maybe a rear spring flip
Maybe a spring over on just the rear end, give it that awesome 70s drag racer rake.
Turning the rear springs around to gain a couple inches more wheelbase. Driveshaft needs to be lengthened a bit and new shock mounts on the crossmember. Cut a bit of metal out of the wheel well.
Seems like easy way to get a bit more length..
- flyingbrick
It would be better to go with 60 or 70 series springs, as their centre pins are actually in the centre not offset like the standard 40 springs.
I looked at turning the springs round on my 40 for better aproach an departure angles, but after some more research I found alot of people on IH8mud found their springs sagged an bent cos the springs werent designed to have the anchor pin on the long side of the spring
On 2nd thought just coil it, do it once do it right
- Sausage Shack
Fakey is rite its really a waste of time turning the springs around because the locating pin isnt in the centre and it creates more problems than its worth and doesnt work properly.
- flyingbrick
why not just take the springs out, have the hole re-drilled further back and put them back in the right way round.
Easy and no bent stuff.
That was one thing people were trying, Redrilling the main leaf an turning the rest of the pack. Not too sure how that worked out, but Id imagine having an extra hole in what are prob already old tired springs will create a weak point an eventually crack
