Sadams Flatdeck 6.0 litre chevy, runs & pulls 3rd gear skids
Re: Sadams Red Flatdeck tidy up and new engine
Oah, Shiny bits.
ford ranger wildtract and sj.
Looks nice Marty/Sig, almost looks like a rat-rod with those pipes.
OK you do have to squint your eyes a bit
Benjamin Franklin
Benjamin Franklin
SP450andLE
^ Those wheels are yuck.
Also, looking good Sadam
- MNC
niblik wrote:thats not a ratty.. this is a ratty...![]()
So this is what you did to the other tub????
Classic use of front guards facing backwards over the rear tires.
Agree that those rims dont suit the wagon.
Where do you find these things Nibs?
PS. Love the suicide door set up!!!
been a bit of work happening lately.sadam has been round a few days doing all the little things ie painting engine,remounting brake,powersteer,fuel lines,drop sump to check for any stray bits in there etc plus a hundred other things. replaced starter motor,made new battery plus earth cables,mounted fuel pump ,made adapter plate for clutch master cyclinder ,made mount for slave cyclinder etc etc .had the motor turning over today off the battery. had the computer powered up and can hear relays and solenoids clicking and opening closing etc .just got to get some high pressure fuel line ,hose clips,fuel filters etc ,plumb fuel system up then try and fire it up .will try for weekend after easter
- Beer_Cruiser
sig wrote:been a bit of work happening lately.sadam has been round a few days doing all the little things ie painting engine,remounting brake,powersteer,fuel lines,drop sump to check for any stray bits in there etc plus a hundred other things. replaced starter motor,made new battery plus earth cables,mounted fuel pump ,made adapter plate for clutch master cyclinder ,made mount for slave cyclinder etc etc .had the motor turning over today off the battery. had the computer powered up and can hear relays and solenoids clicking and opening closing etc .just got to get some high pressure fuel line ,hose clips,fuel filters etc ,plumb fuel system up then try and fire it up .will try for weekend after easter
Can I come for the "fire it up"?
Will bring beer....
Ill bring matches
Beer_Cruiser wrote:sig wrote:been a bit of work happening lately.sadam has been round a few days doing all the little things ie painting engine,remounting brake,powersteer,fuel lines,drop sump to check for any stray bits in there etc plus a hundred other things. replaced starter motor,made new battery plus earth cables,mounted fuel pump ,made adapter plate for clutch master cyclinder ,made mount for slave cyclinder etc etc .had the motor turning over today off the battery. had the computer powered up and can hear relays and solenoids clicking and opening closing etc .just got to get some high pressure fuel line ,hose clips,fuel filters etc ,plumb fuel system up then try and fire it up .will try for weekend after easter
Will bring beer....
might be a good idea .will need a couple of bods to put body back in right position
well guys it lives and breaths .had another bit of a splurge on it today and fired it up.
Sig
wired fuel pump up, did a quick rewire on it, plumbed up fuel lines and primed fuel rail, shifted cab back onto mounts and hooked up ignition feed, kicked it in the guts a couple of times and nothing happened, checked spark and all ok, kicked it in the guts a couple more times and got it fireing, kicked it in the guts once more and it started, ran a bit rough so shut it down and had a bit of a head scratch and kicked it in the guts once ome and it lit up
shit not bad for an engine thats probably been sitting for around 4 years, runs good, real quiet not rattles or knocks so it sounds like its probably low kms
Sadam
Sig
Sadam
- skid
- Tyre Man
sig wrote:well guys it lives and breaths .had another bit of a splurge on it today and fired it up.
Sig
wired fuel pump up, did a quick rewire on it, plumbed up fuel lines and primed fuel rail, shifted cab back onto mounts and hooked up ignition feed, kicked it in the guts a couple of times and nothing happened, checked spark and all ok, kicked it in the guts a couple more times and got it fireing, kicked it in the guts once more and it started, ran a bit rough so shut it down and had a bit of a head scratch and kicked it in the guts once ome and it lit up![]()
Sadam
video or it didn't happen
- possum70
- It was a Ford Hilux I think?
Re: Sadams Red Flatdeck 6.0 litre chevy now runs
the smile on marty's face said it all
i will pit my vid up in the morning....... now which one shall i put up
Rattley old Hilux !!!!
V8 Cruisers Rule!!!!
Sig
GO HARD OR GO HOME !
2015 JK Rubicon
2015 JK Rubicon
AWESOME...............
But abbo missed it...........
Don't have 4wd.
abbo wrote:AWESOME...............![]()
Awsome
- niblik
- Sausage Shack
woohoo sadam and pit crew... soooo, gettin her ready for a southern voyage to godley marty?
niblik wrote:woohoo sadam and pit crew... soooo, gettin her ready for a southern voyage to godley marty?
hadnt put my name down on the list to be fair to all the others that wanted to go this year so there wasnt any overcrowding and too much pressure on Macaulay hut but you never know what may end up happening last minute Nibz
Sadam_Husain wrote:could be a good oppotunity to nick that supercharger off Jims Holden ute if it makes it there![]()
2015 JK Rubicon
2015 JK Rubicon
- tomsoffroad
- Flopsie
Wicked
Come on bring it down for the Godley mission
- MNC
Come on - lets hear this baby ROAR!!!
Start vid!!!!!
Start vid!!!!!
MNC wrote:Come on - lets hear this baby ROAR!!!
Start vid!!!!!![]()
Check back a page, it's there...
- cool__bananas
if you guys want to play with the factory gm ecu ive got all the gear to tune it... haha
cool__bananas wrote:if you guys want to play with the factory gm ecu ive got all the gear to tune it... haha
goooood ,will be in touch
nurse wrote:abbo wrote:AWESOME...............![]()
Awsome........ But nurse wasn't even invited
sig wrote:cool__bananas wrote:if you guys want to play with the factory gm ecu ive got all the gear to tune it... haha
hey your not going to de-tune me down to 90 hp are you
hey thanks for making the phone calls on the desert road the other weekend mitch... we were just cooling the truck down a bit
suzuki1k wrote:MNC wrote:Come on - lets hear this baby ROAR!!!
Start vid!!!!!![]()
On the limiter?
- MNC
Start vid!!!!!![]()
Ha- I have the dumb...
Sounds luvly
Nice work guys.
