engine parts for TD 4.2
Re: engine parts for TD 4.2
How many boosts you running G?
Drive as fast as you can, NOT as fast as you can not.
still running it in ,max is 12lbs
Crash bandicoot wrote:interfridge?
cah?
- crazyclark31
he ment intercooler
oh, sorry, sometime, a bit of cash went west to get it back to running
wof 'd it, the last time, must do cert thing in new year
Sorry to read about your troubles in some of your photos I see your breather from the rocker cover goes some where what have you done there? As I would like to do the same. Also is your new turbo water cooled? And how much was new turbo? Garret are the best! Is it roller bearing?
cost $1450 and a quiet wife, no old school oil cooled unit,breather goes into a airline oil water trap, cheap opition as sod all room under the hood of a safari.
haven't found this turbo on garret web site yet
add 350kms on the speedo was agood run down to Wairere falls south of thompsons track.
have a oil return to the sump to fix,a chassis lube system at moment
found, some dumb ass didn't put gasket between flange an turbo,
oil exicting turbo
oil exicting turbo
so is it all running good now coxsy?? pleased with it??
yes running good, low boost turbo though, low fuel burn too
had a look under the engine last night have oil on sump flowing backwards a leak from oil cooler filter block area, bastard
It sounded real sweet. teething problems
found i dislodged oil dipstick tube getting filters off , oil up to me elbows i will sort it
