toyzuk
- Andrew1706
Re: toysuzi
Hey there, whats involved in wiring in the second alternator? Does it charge just the second battery or the both of them with a relay?
I'm setting up a second battery setup but its pointless adding batteries but no extra charging ability.
Re: toysuzi
1st a main power and earth
then it is a bit more involved
on a nippion denso alt with in built reg has a L,IG and a S for the 3 wire plug on
(L,IG and S is normally printed on the side of the alternator)
the L goes to a light(about 3 watt) which goes to the ignition so puts power both ways
so the light dose not go. when the alt stops charging it changes the L wire from power to earth
the IG goes straight to the ignition as a exciter wire
and the S is a signal wire and goes straight to the positive of the battery
some alternators may not have all 3
as i founded out not all alternators have in built regulators so choose carefully
also some are better than others
only chargers one of the two batteries as to keep them completely separate
toysuzi:(SJ413) 3Y E surf engnie, 6" coil kit (RRO). toy diffs (4.88 R&P) & toy hilux box and t-case.
ifs toy power steering, 6" Bushwacker fender flares (RRO). ect
Re: toysuzi
as they may have shown footage of me putting it on its side (we lent them our vid)
i did not post up any pics(from the top of the south winch challenge)
he is a step by step of what we did on the second tip over (stage 2)
the fist one a night i do not have any pics
other then the tip overs (a bit of panel damage) we only slightly bent the trans cross member up making the drive
shaft rub on a rear suspension cross member and a small leak from a bent rim so no real mechanical damage.
small winch (stage 2)
when we get our vid back for the Suzuki Xtreme tv guys i will post same of it up.
Re: toysuzi
Yes they didn't show much but it was good footage and it had you and us in it
about 20 mins of footage from a whole days video - an edited long version would be great!
Re: toysuzi
only problem with the footage my mates took was they didn't go around and get any vids of others
so seeing others in action was great.
(get to see what you did good and bad)
Re: toysuzi
Good to see noone was hurt & the truck only got slightly scared
Its not good when you start spending money and time on repairs rather than " R&D"!
Looking forward to the vid link!
84 SJ410V, 1000cc, OME 2" spring kit , 2" extended Shackles, 1&3/4 "extractors and 15" coby ,rear lockrite, 29" SATs
This is not the greatest truck in the world..this is a tribute!
Re: toysuzi
very little done but a couple of the things i have
new cross member
old cross member which hung done and got caught up a lot
front of the chassis has got beefed up with 3mm plate
went to std steering arms for
$130 all up (from toyota) for hole set up. can't go wrong so go spears at the same time
play day pic
starting to chop the rear guard out as have a bit of rust and to fit 35" silverstones at same stage
new cross member
play day pic
- Bulletproof
Re: toysuzi
[quote="toysuzi"]very little done but a couple of the things i have
Hi James
I hope you are not using the 35s on Nelson club trips
Cheers Richard
Hi James
Cheers Richard
Never say die, up man and try
Re: toysuzi
may be able to as the ones in savs shop came to 33.5" on 8" rims and 30psi so a litte bit of wear and you can'
as in club rules it states
“33” or equivalent measured 840mm tyres
the tires will still only be used for comps ect for some time and
still use the simexs for club trips
Re: toysuzi
went out playing again instead of working on zuk
bottom less bog
stuck
very stuck
long winch up a boggy valley
playing
bottom less bog
stuck
very stuck
playing
- chchzookfan
- Bush Crasher
Re: toysuzi
kikawa track clearing /play day
35 silverstones on the zuk
pic of scottys new surf
- Bulletproof
Re: toysuzi
Hi James
A little birdie told me you didn't make it up Petrol Hill last weekend.
You were covered in a lot of mud when I saw you on Sunday.
Cheers Riichard
Cheers Riichard
Re: toysuzi
Bulletproof wrote:Hi James
Cheers Riichard
Wheelbase must be too short eh Richard!
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Re: toysuzi
i did not take the zuk to Petrol Hill even if i did i would not make it up
as the zuk is not the best on hills
- Bulletproof
Re: toysuzi
toysuzi wrote:i did not take the zuk to Petrol Hill even if i did i would not make it up
You wern't singled out . It was a general comment that no one drove up Petrol Hill.
Sounds like you had a good weekend. Been talking to Pat ,Rowan and Sav.
Cheers Richard
Re: toysuzi
small vid of the suzuki in action
- Bulletproof
Re: toysuzi
toysuzi wrote:small vid of the suzuki i action
Was that at Alistairs place James ?
About as good as my effort while we were picking up pegs at the trial.
cheers Richard
Re: toysuzi
Was that at Alistairs place James ? yep
it needs a bit more power with the new tyres
but i did reverse out of the bog on the fist vid
2nd attempt i had to winch out of the bog
Re: toysuzi
I see in an earlier post you went from 14" springs to 12". Do you still have the 14" ones? Do you want to part with them? The 12" vitara ones I have are a bit short and soft.
Re: toysuzi
You still after a motor? my mates got a cheap 4y? theres a guy over these ways with a rover v8 in his zuk goes like stink
Re: toysuzi
meatc wrote:I see in an earlier post you went from 14" springs to 12". Do you still have the 14" ones? Do you want to part with them? The 12" vitara ones I have are a bit short and soft.
still have the springs not sure if they will work as they do not have very much up travel
just std coil over springs
http://www.4wdbits.co.nz/ProductsList.aspx?CategoryID=53&selection=18
Re: toysuzi
madterrano wrote:You still after a motor? my mates got a cheap 4y? theres a guy over these ways with a rover v8 in his zuk goes like stink
may be getting a comy v6 not sure yet so dont need the motor thanks
Re: toysuzi
Re: toysuzi
pics of commy v6 in zuk
Re: toysuzi
commonwhore motor in sj413=
- suzukisport
Re: toysuzi
zukmeista wrote:commonwhore motor in sj413=
Supercharged Commodore motor in sj413=
suzookyman
Re: toysuzi
suzukisport wrote:zukmeista wrote:commonwhore motor in sj413=
Supercharged Commodore motor in sj413=![]()
BRING IT ON!
Re: toysuzi
Jeez, I would have thought you guys would understand power isn't everything after seeing the mighty jellybean in action
Do I hear the sound of a chassis snapping
Re: toysuzi
there will be more power need to get it on the road first
the motor from
will be going into it
the motor from
