Maybe in the ute...........
Auber Gauges
Re: Auber Gauges
Not sure it would suit the retro interior and the dial gauge pack I will fit (when I save up for them and the wiring kit
- Im a Tumor
- Bush Crasher
Re: Auber Gauges
Wow these gauges certainly look the biz!
Do you need to buy the egt probe etc seperatly or do they come with the gauge?
Re: Auber Gauges
kiwipete wrote:slidenyo wrote:looks pretty flash,
I'm definitely heading towards two of these , egt/boost + trans temp/watertemp and then possibly a third for oil pressure/volts.
Pretty sure the auto sparkie will be happy for half a days work
Wire them in yourself, it aint that hard to do and you'll save yourself some coin too
I definitely could but the sparkie will also be wiring in a alarm,
and tbh wiring is my pet hate.
Wild_South
Re: Auber Gauges
Could somebody help me out here? Electrics and I are not the best of friends, that's for sure.
Which do I go for - they are both an EGT gauge but different sensors I believe?
http://www.auberins.com/index.php?main_ ... cts_id=230
OR
http://www.auberins.com/index.php?main_ ... cts_id=231
Next, I'll be running it in a '93 1KZ Surf with dual batteries. What voltage option to I select? 12v or 24v
And lastly, what mounting option did you guys choose?
Cheers!
OR
Cheers!
1997 Toyota Surf KZN185 Intercooled, Silver/Grey, 2" Suspension Lift, 285/75/r16 Hercules Terra Trac D/T, 16x8 ROH Black Track Steelies, Roof Cage, 42" LED Light Bar, Limb Risers, Snorkel, Auber Gauges, Thicker Core Radiator, MCC Winch Bar
Mr Revhead
Re: Auber Gauges
If you look at the probes page you can read the specs on each.
I went for this one http://www.auberins.com/index.php?main_ ... cts_id=182
Currently waiting for mine to arrive!
Re: Auber Gauges
Wild_South wrote:Could somebody help me out here? Electrics and I are not the best of friends, that's for sure.
OR
Cheers!
Go for the 2nd one in post as the first one has a hose clamp to hold the probe in place?
The 2nd one is designed to be drilled and tapped in place.
Ph 0212078472
Ph 0212078472
Wild_South
Re: Auber Gauges
kiwipete wrote:Wild_South wrote:Could somebody help me out here? Electrics and I are not the best of friends, that's for sure.
OR
Cheers!
Your post has confused me Pete haha. Hang on, did you mean to say 2nd one for both of those?
How about the voltage and mounting options?
Re: Auber Gauges
http://www.auberins.com/index.php?main_page=product_info&cPath=5_26&products_id=231
This one, being the second one posted in the question.
If your truck is 12V then select 12V
If it is 24V then select 24V
The mounting type is a personal preference, just depends what taps you have available to tap it in?
As for the LED colour, well it comes down to the age old argument, left hand or right hand; again it is a personal preference.
Ph 0212078472
Ph 0212078472
Re: Auber Gauges
So regarding the double gauge what is the shipping costs when you order them from the website?.
