Ore Welly Wainui Coast to ocean beach Trip
ok weather update its probably going to be raining so its still going ahead....bring a raincoat or something......
Just a reminder we haven't run trip in here yet so I want everyone on best behaviour, there are areas that we are allowed to play and area's that we aren't. we will be shown where to go. If there are any issues then I'm going to unbolt some prado parts and start beating people with them (or give 12 hr towhook lectures). We have to stay off the dunes at ocean beach as well.
REMINDER THIS TRIP IS ON THIS WEEKEND
12 August 2007
ORE Assn Trip - Wainui Coast to Ocean Beach
Trip Grade: 1-2 (out of 5)
12 Aug 2007
Meeting point: Public carpark @ Wainui Beach
To get to the meeting point get to Wainui(omata) and then just keep heading thru...past KFC Bro, past the BP and then keap heading down the coast, when you get to the next roundabout and set of shops keep moving on, past the tip 10 mins down the road, the forest park is 5 mins further down.....all the way to the coast....when you see the watery thingy follow the road to the left and there is a carpark on the right which should be full of 4wd's....if you go thru the "private property" sign you have gone too far
Meeting Time: 9.30am
Drivers Briefing: 9.45am
Trip Start Time: 10.00am
Trip fee: $15
Visitor fee of $5 applies for anyone not a NZ4wd Assn member otherwise bring your 4wd Assn membership cards or join here http://www.offroadexpress.co.nz/modules ... x&cPath=38
PLEASE BRING CORRECT CHANGE IF POSSIBLE
BYO Food & Drink
Some optional play areas
Rated Recovery points required for those that use the optional play area's, however this is a shiny trip and I will allow non rated hooks on this trip.
This is a joint trip between ORE Assn and the Wellington Family 4x4 club
Can come back over the Rimutaka's or back the way we came, WN Family will lead it for us this time as I haven't been there for ages, will run our own trips in there after this as the landowner will get to know us. and its a good opportunity to meet another club.
If you get lost etc PRS Ch 10 (if in range) or try me on 027 479 2417
curly12
Post by curly12 »
Dammit, breakdown at work so won't be able to make it. :(
the Mudzilla's don't like the sand much and either dig in or pull you to the either side of where you want to go....so it was a bit interesting going over here
This is where rob broke his CV.....his truck came up a good M and then went crack when it hit the ground...
More pics are here....
http://www.offroadexpress.co.nz/modules ... _album.php
looking at running an "ORE" one in Nov and then regularly
abbo
Post by abbo »
that was my 1st trip good day will be keen to do that again 8)
suzuki_mike
Post by suzuki_mike »
Good trip... well apart from when I threw up. Learnt lots though
Mattman
Post by Mattman »
Good photo's Jerry, looks like it was a good trip.
Matt.
re10
Stropper
Post by re10 »
How far around can you get from the Ocean Beach side until you run into private property??
Return to “Planning a trip?”
