-- 16 Sept Aotea Block Pegged Hazard Play/Training Day --
DBWRacing wrote:Hey, my mates boss wants to bring his 07 hilux, reckon we could trash it for him
Well lets see.. will he let us drive it? If not then we can always let him be the passenger with someone while his new one goes for a small ride through the long bog.... he he he last two people that went through there stuffed their trucks... cough Robo cough... .
Re: training
coxsy wrote:from way up here in sunny auckland looks abit wet and cool down there hope your having fun
no rain, just overcast down here today :thumright:
shit what a day, good range of hazards pegged out that were managable for most, sometimes it just took a bit of attitude to get through
Ryan, I think your going to be giving redzuki a good run for his money now you've got that zuk running properly :thumright:
kept my cv's intact but alas there were a few others that came away with breakages
http://www.offroadexpress.co.nz/modules ... _album.php
Disclaimer: Please note these photos are copyrighted to myself, and cannot be used outside of ORE or in any magazine article or newspaper or submission to DOC without my express permission in triplicate, this includes Bruce Mason and any other Greenie. heavy penalties will apply which may include my lawyer and some 4wd's making new tracks on your front lawn
He was going backwards here
Suzuki1k (Reece)
Suzuki1k (Reece)
- Beer_Cruiser
Here's the damage
Otherwise a really good day
Were the diff internals buggered as well? if you have trouble finding another one try TePuke Partsworld, they are specilist Zuk wreckers and really good. not sure if the 1600 diff is the same as the 2000/2500 one ie will a 2.0/2.5 diff bolt on easy and be a bit stronger and not screw your diff ratios.
This is Tepuke on TM here I think ? http://www.trademe.co.nz/Trade-Me-Motor ... 37.htm?p=2
It all seems to be there, The pinion is buggered, think I could probably get away with just a new pinion and the back piece of the case. The 1.6 has 5.12 gears which are different to the other models and they're the lowest ratio so it won't be worth getting one from one of the other models. The thing it may be worth getting depending on the cost would be one of the steel diffs. Have already asked a couple of questions to the wreckers on trademe so will see what the outcome of that is.
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
awsome day!!!
. Saddam--it wasnt running nice,so you better watch out when it is and i get the locker in!!
Thanks jerry......well organised day...........
I must remember to take my foot of the go pedal every now and then!!
- downunderxj
Thanks Jerry, really enjoyed today. A lot more interaction with the other ORE members too, rather than playing follow the leader.
I only had the one moment when the Jeep was being recovered from the boggy area and tried to turn turtle, but thanks to the recovery crew all ended up well
Ian
Ian
'95 Jeep Cherokee (XJ)
1936 Ford Flathead V8 Colonial Cab (restoration project)
91Rangie wrote:Had a great time good to meet some of you guys and thanks Jerry
Pulled the axles out to check the dammage
Blown rear diff and a slightly disfigured axle
If you're in the market for some spare axles now I have a set, got a diff head too if needed.
PM me if interested.
- downunderxj
I just saw the response to your auction question
My diff has broken at the backing plate and the pinion is broken, The rest of the internals seem OK. Could you please advise the price for just the back piece with pinion attached in alloy. 5.125 ratio. Alternatively I would look at rebuilding it in a steel casing because of the extra strength so whats the price on that? posted by: nstacey (83 ) 1:08 pm, Mon 17 Sep
The crownwheel and pinion are a matched pair and I will not sell one without the other. Alloy diffhead with 5.125:1 internals $995.00, Complete steel front diff with 5.125 internals $ 2150.00. 5:02 pm, Mon 17 Sep
Can you put a difflocker or an auto locker/lockright in that supplies the same parts and would this be cheaper????
