I just have to find a place where it will fit.
petefj40 wrote:
Can anyone tell me some problems they've come across and how they got round them please?
Thanks.
Pete.
Thanks.
Pete.
Over hanging trees![]()
Dont know what the fix for it is yet?
SMOKEY wrote:Hi Pete, Do a Google search on Hella HID work lights, we run these on our vehicles at work that work through the night. They turn night into day. Hella Xenon HID work lights ( High Intensity Discharge ) draw under 3 amps and are 2.5 times brighter than conventional lamps. Warning they are not cheap. Two of these up top and two Hella 4000 or equivalent mounted on the top of the bull bar and you would have all the candle power you would want. TWL on Blenheim Rd have a good range of Hella Lighting.
IT'S NOT THE AMOUNT YOU HAVE GOT, IT'S HOW YOU USE IT,
FITZY.
MNC wrote:Pete,
I know money seams to be no issue for you but dont buy a pre-made top. Go to a marine & Auto upholstery place. Should only be $500 for a custom set up.
PS. My truck will still smoke you no matter how much you spendIts all about the loose nut at the wheel.
petefj40 wrote:MNC wrote:... if mine doesn't beat yours on the 1/4 mile I'll be bolting on a supercharger to make sure it does. (as well as wheelie bars)
petefj40 wrote:This is the plate I'm thinking about putting on me truck.![]()
My kids say adding the NZ stars and fern on the sides of it would look, "gay".I'm seriously thinking of purchasing it.
Thanks.
Pete.
MNC wrote:Pete,
Mattman wrote:Looks great Pete.
How come you have gone for two 12's instead of the 16?
I did the math and you get a lot more airflow with a good 16.
Matt.
Mattman wrote:what I found was that the CFM of the 12's was generally a lot less than the 16's
jumper wrote:It would depend on the speed and blade design of both sizes of fans as to which is better. What are the 12in fans from, i have a repco 12in with lots of thin rectangular blades with a slight curve and a unknown 12in with 4 large blades with a slight curve on my 350 and it seems to be working fine.
But i will be upgrading to a set of dual v8 falcon fans as they are a better fan wreaker wants $250+, if i could get a taurus fan that would be better.
