bj40 build...
Re: bj40 build...
I wish I had just used a line lock for my Handbrake. Would have saved days of head f**king and silly things like custom disk rotors on the back of the transfercase.
There's gotta be some rocks round here SOMEWHERE!
Re: bj40 build...
Good work elnibby
I will have to reserve the passangers seat for a trip one day after all the greif I have given you over the build
I will bring lunch
(021) 02388443
(021) 02388443
Re: bj40 build...
keep up the good work
IM HARD AT WORK CANT U SEE THAT
- niblik
- Sausage Shack
Re: bj40 build...
guestynz wrote:wat were the rear spring out of
they came from a either a disco or rangie, pair of rears..
sweet as pr.. i gotta finish it first..
Re: bj40 build...
niblik wrote:sweet as pr.. i gotta finish it first..
Shouldn't take that long
(021) 02388443
(021) 02388443
- niblik
- Sausage Shack
Re: bj40 build...
after a bit of time off from the fawdy what with playin around on/in vomitron, its time to get back into it..
after the debarcle with the thrust bearing version one, i had installed a second bearin. once it ws tested i found that there was a slight rattle comin form within the bellhousing.. sigh!!
so then came the strip down of twin transfers and gearbox and pull the clutch cover and plate off..
hmmmmmmmmmm....
no visual sign of wear and tear / rubbin.. with much thanks to classic cruiser spares who took to clutch specialists and deduced there was a metal pair of rings that when the pedal was mashed, would loosen, giving the rattle.
he then sourced a new heavy duty fawker so chucked that in..
so thanks heaps for that fella..
so put the gearbox and parts all back in, filled with fluids, levers back on, tested, all goodly!! awshum!!!
also added another crossmember by where the stocko one used to be.. thought i'd add it there for strength and future useful plans.. will get photo's of that sometime, cos i can..
now some tow hooks and testin time..
have played with the idea of guards of some sort.. but will work on that more later..
hmmmmmmmmmm....
Re: bj40 build...
whats with the side mounted diff head about mid way on the drivers side.. for the yokel rotisserie?
- niblik
- Sausage Shack
Re: bj40 build...
its a spare unwanted 40 diff, but now ya mention it, that'll be a mean spit roasting machine..
- niblik
- Sausage Shack
Re: bj40 build...
made a removable winch mount for the fawdy..
got a superchump winch for it.. should do for the time being, till version 2 comes along..
firstly lost some weight off the front, the front spring hangers fell off. made the mount to sheath under the crossmember and encapsulate the winch bolts, through the mounting plate, winch and bottom gusset mounts.. it also has another couple of bolts through the top plate and tapped into the top of the crossmember.. perhaps i might put another long bolt right through the entire crossmember and winch plate as the other two mounts have been done, just no gusset.
- ClassicCruiserSpares
- Sausage Shack
Re: bj40 build...
That come up well fulla looks goodly, you mounting solenoids in the engine bay? you wouldnt have any space left in there
Re: bj40 build...
ClassicCruiserSpares wrote:That come up well fulla looks goodly, you mounting solenoids in the engine bay? you shouldnt have any space left in there
Fixed it. But as it is a few cylinders shy of making good noises, he has heaps of room
- niblik
- Sausage Shack
Re: bj40 build...
ClassicCruiserSpares wrote:That come up well fulla looks goodly, you mounting solenoids in the engine bay? you wouldnt have any space left in there
solenoids and stuff mounts on top i believe.. i've not hooked it up yet.. mount was today.. wiring to come..
rokhound wrote:ClassicCruiserSpares wrote:That come up well fulla looks goodly, you mounting solenoids in the engine bay? you shouldnt have any space left in there
Fixed it. But as it is a few cylinders shy of making good noises, he has heaps of room![]()
yeah, but i'm comfortable with my penis size fella...
Re: bj40 build...
nicelllly done nibz
Re: bj40 build...
i'm guessing your gonna cap the end of the chassis rails?? make caps extend onto crossmember and then the whole lot be stronger.
mount the solenoid in the engine bay or the cab. let me know how much cable you need and i'll send up some nice heavy stuff with the mrs when she comes to get the diff bits in early jan..
- niblik
- Sausage Shack
Re: bj40 build...
callum007 wrote:i'm guessing your gonna cap the end of the chassis rails?? make caps extend onto crossmember and then the whole lot be stronger.
already there chap..
jase and callum, mounting solenoids in-cab is probably the go..
callum007 wrote: let me know how much cable you need and i'll send up some nice heavy stuff with the mrs when she comes to get the diff bits in early jan..
sweet as chap.. i'll keep in touch..
- niblik
- Sausage Shack
Re: bj40 build...
bolted trans cover down properly, made provisions for front tow hook to bolt down, just need the bolt.. labelled glow and starter switches
.. made some caps for ends of chassis rails.. put on some bonnet hooks.. then mucked around with a guards idea..
Re: bj40 build...
Lynx wrote:Churrrrrrrr
Re: bj40 build...
mean maori mean... looks like she needs hydro's.
Re: bj40 build...
Rock on later in the week.
Hope all goes well
Hope all goes well
Re: bj40 build...
This thing must be so close to being finished! Guards look sweet. Going to make them removable?
Whens the first trip out?
Re: bj40 build...
heard he was bringing it up here
- niblik
- Sausage Shack
Re: bj40 build...
DMcCready wrote:Going to make them removable?
they are indeed dude.. bolted up into the side bar work and front bib.. 5 bolts and its gone..
mounted front tow hook, made other guard as i wanted to keep it lookin factory, finished weldin on the end caps for chassis rails, painted winch mount and end caps, mounted winch, wired it up and it works, thus far..
- niblik
- Sausage Shack
Re: bj40 build...
DMcCready wrote:Whens the first trip out?
today!
took the fawdy up worsley's today to test out the running gear and see 'what gives'... was a good day weather wise with a couple of like minded wheelers joining the fun..
i didnt get any pics or vids.. think a couple of others did.. just gotta wait to get it uploaded..
all the suspension travel went well with the coilovers and rears doin what theyre meant to.. got twisted up a few times, at one stage the passengers b pillar got a push in whilst i tried to take a 'different line'..
did get stuck and try the winch, but the bolts were'nt up to it but the good news is the bracket i made for it was, so just finish mounting the bracket (where it bolts to front crossmember, need some high tensile bolts as i wasnt fully finished with the mounting of the winch..) and it should be good for another decent testin..
power steering pump.. i had my rust inhibitor goin hard as the front seal on the main shaft has got a leak (knew this prior to heading out) so will refurb the pump soonly..
also the front arb difflock doesnt seem to be unlocking properly.. disengage and its still like the front has a welded nugget in there.. must be how i've plumbed up the arb perhaps.. powersteer wont be helpin things..
it climbs really well, no 'yawning' in the front and it sure is a bloody pleasure to wheel some coils offroad!!
all up i'm pretty happy with how the truck went..
fingers crossed the vids and pics follow soonly..
- Sausage Shack
Re: bj40 build...
It was a great day out and i had a ball, i gave my rear panels a good whack also. Its a credit to Nibz to see his truck out today and all his hard work payed off, its a very capable truck and not alot that will stop this thing. Good work fulla.
Im just resizing some pics now so will be up shortly.
- Sausage Shack
Re: bj40 build...
Here are a couple of pics i got.
Re: bj40 build...
Shit hot nibz, looks awesome, its got a little bit of flex aye...
Re: bj40 build...
Good shiat my nigs. looks like the grass is growing up there. How did it climb up the big rock in the rock garden?
Re: bj40 build...
awesome ya little gaysian
loled reading the 1st page again (all those years ago
- niblik
- Sausage Shack
Re: bj40 build...
it went well up the big rock in the garden fella.. plenty of other ruts and stuff to get all twisted in too.. was good to choose lines a bit different to norm.. i love the oober slow crawlin styles..
looks like theres a bit of fence down and some peeps have been drivin up inside the treeline if thats right? its not us 4 wheelers is it?
lol rexo.. its changed direction a couple of times.. "oh, i'll just look at this wiring issue and lift the body off, oh, might just soa it, oh might coil rear, oh might coil front...
likin where it ended up..
