Page 30 of 43
Posted: Mon Jul 13, 2009 8:30 pm
by Andrew1706
Crikey, the almighty Bulletproof is coming to Auckland!!!!
Would like to catch up with you
Posted: Tue Jul 14, 2009 4:54 am
by T-Boon
I think we might have to do a woodhill group trip ?
Posted: Tue Jul 14, 2009 8:26 am
by Bulletproof
T-Boon wrote:I think we might have to do a woodhill group trip ?
The trip is out of my control as I am only tagging along with Mudzilla and Jafa who are doing the organizing
We'll keep you posted nearer the time.
Cheers Richard
PS Early next year we will probably have a similar trip down here on the Westcoast.
Posted: Tue Jul 14, 2009 2:18 pm
by PR
Bulletproof wrote: PS Early next year we will probably have a similar trip down here on the Westcoast.
I would be keen if you dont mind dragging a large seal out of the bogs
Posted: Wed Jul 15, 2009 1:16 pm
by Shane
PR wrote:Bulletproof wrote: PS Early next year we will probably have a similar trip down here on the Westcoast.
You not taking your truck
Posted: Thu Jul 16, 2009 4:21 pm
by PR
Shane wrote:PR wrote:Bulletproof wrote: PS Early next year we will probably have a similar trip down here on the Westcoast.
Yep
the new hair dryer should be on and I might have a five link front end by then too
just have to finish all the bar work on the missus pajero
Posted: Sat Jul 25, 2009 5:48 pm
by Bulletproof
Because my 5l has been modified with supercharger ,extractors, and fuel pump I like to regulary check for anything going wrong.
So today the glow plugs came out for their annual check. While they were out I gave it a compression check.
I fitted the supercharger 5 years ago at 36000 as I wanted the motor to run in properly first.
Here are the compression figures over time
After driving it with modified exhaust and intake for a couple of years
At 18,000 585 590 590 590
At 42,000 615 611 608 613 in 2004 after supercharger fitted
At 63,000 603 600 595 602 Jan 2007
At 83,600 595 590 595 595 With luke warm motor after sitting for 1.5 hrs
Todays lowest reading
The motor has now done 47500 since fitting the supercharger . Compressions still good and still running 25lbs oil pressure hot at idle so I don't think blowing the motor has had any bad results
Cheers Richard
Posted: Sat Jul 25, 2009 8:44 pm
by vvega
as long as there nice and even as they are there your on the money
i get 230 psi on mine .. but then its a petrol
Posted: Sun Jul 26, 2009 6:55 pm
by Bulletproof
While checking glow plugs and compression I see the intercooler needs abit of work
One of the big disadvantages of a top intercooler is that the fins get flattened with branches and shit getting in there and being shaken around with the motor shake.
Cheers Richard
Posted: Thu Aug 20, 2009 3:22 pm
by Bulletproof
A few days before going to Ralleywoods last weekend I decided to modify the Steering because the drag link was getting bent on every 2nd trip.
I have now fitted a BJ60 drag link with the bigger tapered pins and the springs for shocking both ends.
To gain hieght I have now fitted the drag link on the top side of the left hand king pin arm which lifts it about 75mm. It also keeps it in a straighter line whichs makes the steering lighter as well. Because the tapered pin is bigger than the hilux arm we only had to lathe a 4 degree taper from the top side.
This is how it was
with the mod
The steer damper is also in a better line now as well with BJ 60 arm
Came back from Ralleywoods and it is still like brand new and not the slightest bend.
Cheers Richard
PS My new diff parts arrived in NZ on Wed so will soon be able to strenghten the rear diff.
Posted: Sun Aug 23, 2009 2:35 pm
by Bulletproof
Sick of wearing out my Simexs on the road
After getting home from Rallywoods on Monday I have decided to modify th deck so that I can carry the 35 ET simexs on the back.
Out with angle grinder today and good bye guards. Amazing the amount of room they take.
Cheers Richard
Posted: Sun Aug 23, 2009 2:53 pm
by J_Dub
what are your plans with the guards?
ive just been working on mine and thinking about guard clearance, im making fibreglass front guards and want to chop the rear
Posted: Sun Aug 23, 2009 4:04 pm
by Bulletproof
J_Dub wrote:what are your plans with the guards?
I have a 3inch lift in the deck so the guards do nothing except make it hard to load the deck. Better to have more storage area.
Next week end will weld new panels in.
Cheers Richard
Posted: Tue Aug 25, 2009 9:52 am
by Bulletproof
Some Videos from our Aka's trip
Hilux doing what it does best where most others struggled
Cheers Richard
Posted: Tue Aug 25, 2009 2:43 pm
by haydgq
Nice one Richard you made that last hill look so easy.
Have you got a front locker and do you have CV breaking issues and are you running standard parts in your front end?, You know my uncle Vic that has the twin locked safari and he reakons with the front locker in he's popping Cv's all day and he's quiet a smooth driver, Well usually anyway.!! Cheers Cya
Posted: Tue Aug 25, 2009 3:25 pm
by albundy
I've got a twin locked safari on 35" silverstones and have only ever broken one CV. What type of hubs is he using, maybe that's the problem, hubs are stronger then CV's???? I have gone through 4 sets of hubs though. Hubs are way cheaper then CV's.
Al
Posted: Tue Aug 25, 2009 9:10 pm
by haydgq
albundy wrote:I've got a twin locked safari on 35" silverstones and have only ever broken one CV. What type of hubs is he using, maybe that's the problem, hubs are stronger then CV's???? I have gone through 4 sets of hubs though. Hubs are way cheaper then CV's.
Al
Yea im not sure why he breaks them, I just re-call him saying that was the reason he didnt use the front air locker very much and also that is was capable enough with just the rear locker used and with Simex's, But i do know he runs the factory Nissan hubs.
I just wondered how the Hilux CV's were holding up in trucks like Richards that really get used and driven in hard yakka stuff.
Posted: Wed Aug 26, 2009 7:40 am
by Bulletproof
haydgq wrote:albundy wrote:I've got a twin locked safari on 35" silverstones and have only ever broken one CV. What type of hubs is he using, maybe that's the problem, hubs are stronger then CV's???? I have gone through 4 sets of hubs though. Hubs are way cheaper then CV's.
Al
To answer both questions. I have done a number of trips with Al and Vic. Vics Is a lot more competitive and aggressive than Al and uses his right foot more which is probably why he breaks CVs. He is also heavier and has more power.
Back on topic. I have PZ70 cruiser Front diff with the bigger CVs and have only broken 1 in the last 7-8 years and even then it was my fault by slamming into a big rock under power.
People think I am a hard driver but that is not true because I drive the hilux more like a tractor and never drop my clutch while at high revs.
I also only use the front locker when I know there is slip on the ground
Cheers Richard
Posted: Wed Aug 26, 2009 8:53 am
by haydgq
Yea thats true Vic's has a lot more power than a N/A TD42 and also more than a factory turbo TD42T model and he is known to be a aggressive driver and yes that truck is VERY heavy with all the gear he carrys around.
Once he is back from touring around OZ ill be heading down to Lyford to have another trip with him and Steph, They might leave Vic's truck in OZ and use Steph's GQ Shorty while they are back.
Cheers and i prob should rear your build up in full once ive time as there are a few pages there
Posted: Wed Aug 26, 2009 6:46 pm
by Bulletproof
A few more Aka Clips
This is a repeat but had to do it
Cheers Richard
Posted: Fri Aug 28, 2009 8:45 pm
by Andrew1706
I'm sure it's been mentioned in this thread but why did you choose the supercharger over the factory L series turbo?
No spooling obviously, what boost are you running and when does it come in?
Just weighing up options - I have a friend with a 5L for sale and I have a 2LT and I'm impressed with the performance of your motor and swapping the turbo gear over isn't too hard.
Posted: Fri Aug 28, 2009 9:26 pm
by Bulletproof
Andrew1706 wrote:I'm sure it's been mentioned in this thread but why did you choose the supercharger over the factory L series turbo?
The choice of motors and what to do was a hard one.
I wanted a low K motor and there was a choice of two. A 1KZ with intercooler and 14000ks for $4500 or the 5L with 9000ks for just under $8000.
I do alot of deep water so I didn't like an Electronic pump so this went against the 1Kz . I also dont like the back pressure caused by a Turbo and the heat build up as a result.
I also don't like the turbo lag for 4 wheeling.
The 5L on the other hand had a manual pump so that appealed to me. I thought that I would risk modifying one.
The first thing I did was to throw away the exhaust and design Extractors to suck out the heat. I increased the exhaust ports from 35 to 38mm with 2.5 inch exhaust. After this I threw the inlet system away and fitted the Supercharger to blow cold air into the motor and give a good cross flow of air.
Blow in one side and suck it out the other side of the motor is my motto.
After this I fitted a top off a 2LT fuel pump to give extra fuel boost
I like the Supercharger because I have 4lbs of boost at idle and it quickly rises through 1000revs which give instant power and control 4 wheeling. I am running 10lbs into the intercooler.
I have now done 75000 ks without any adverse things showing up and am completely happy with the setup. I am running 4.5 diffs with 35inch ET simexs and dont run out of power where all my friends with the 1kzs are using 4.8 diffs and dont have the quick response I have.
There are lots of trucks like Jafa's that out perform me and there setups may be worth considering. Mine is just a bit better than average club truck.
Cheers Richard
Posted: Fri Aug 28, 2009 10:03 pm
by mudzilla
Bulletproof wrote: Mine is just a bit better than average club truck.
Cheers Richard
Ummm ,, Yeah
Posted: Sun Aug 30, 2009 11:30 am
by Bulletproof
After Haynzy's expierence, Just a reminder if scum are looking.
Arms fit nicely while you still have them
Simexs also fit nicely with guards removed and one step closer to my trip with Mudzilla in Oct
Cheers Richard
Posted: Sun Aug 30, 2009 11:57 am
by haynzy
Bulletproof wrote:After Haynzy's expierence, Just a reminder if scum are looking.
Cheers Richard
dont you worry richard if i had of heard them I would have ripped their arms off but my useless dogs didnt even wake up (bloody beagles)
Posted: Sat Sep 05, 2009 8:02 pm
by Bulletproof
A bit of an anti climax .
My new Yukon Ring & pinion gears arrived this week to find they are not what I need for the latest stronger diff housing
You can make it work by add O.241 inch shims but not ideal.
The diff head is the same as the V6 and has the 8.125 diff instead of the 8 inch hilux so now have to wait for a new parts to arrive from the USA.
Cheers Richard
Posted: Sun Sep 06, 2009 6:24 pm
by Bulletproof
A picture of the hilux climbing out of "Alice Way" at Ralleywoods .
Cheers Richard
Posted: Mon Sep 07, 2009 6:32 pm
by toysuzi
so hear you are rejoining the nelson club
Posted: Mon Sep 07, 2009 7:56 pm
by Bulletproof
Posted: Thu Sep 10, 2009 6:51 pm
by Bulletproof
