another terrano/safari project = terrari
passengerpete
Re: another terrano project.
Post by passengerpete »
tomsoffroad wrote:
im not a certified welder so will have to get someone else to do that
Ohh Ohh Ohh (jumping up and down hand in the air :lol: ) I am :mrgreen:
ok sorted thanks tom much appreciated nice and easy, will be in contact soonish.
passengerpete
it can be done! a pic says a thousand words so...
big thanks to Nigel at B Spec Engineering for all his work too.
Last edited by passengerpete on Mon Apr 21, 2014 8:17 am, edited 3 times in total.
passengerpete
slow progress but progress none the less. painted the bell housing, brought a gq front drive shaft on tm, just need to find a rear one now. started pulling apart the terrano, took the drive shafts off and drained the oils and unplugged all plugs and hoses. have made a play date with tom in three weeks. so i need to put a into g a bit.
madlux
Post by madlux »
nice ae in the backround :wink:
wax
Post by wax »
Im thinking that gearbox will be up to the stress of the td27
passengerpete
had a few minutes up my sleeve tonight so took out the front seats and carpet, and some interior trim and the big cover plate where the auto comes through. had a wee measure and the safari gear stick sit dead center of existing hole. only thing thing that might cause a problem is at first glance the new gearbox will sit quite high in the chassis and may be close to trans tunnel. by high in the the chassis i mean that the new gearbox is taller then old one and will fill up the space left by the body lift. hard to tell until i get it in.
passengerpete
brought a new spigot bearing and a second hand rear safari drive shaft today. removed the front torsion bar suspension, to make more room for the removal of old auto, which ill do on Friday to leave weekend free for dummy fitting new box.
passengerpete
brought a manual peddle box today. and pulled out the old auto and that was a pain in the ass.
passengerpete
spent all day on truck and got nowhere,
i could not undo the flexy plate bolts so had to go out and buy a new strong arm bar and then jam bolts and screwdrivers in to stop it spinning.i put in backing plate,flywheel ans clutch assembly and then dragged the heavy as hell gq gearbox under the terrano.not sure where the day went. lifted box up for a wee look and see. and it is going to hit the front of the trans tunnel. but only just, clears every thing else but was not completely in, so might be a wee bit premature. any way so pics
in this pic the box still needs to go up 15mm and forward 150mm so the gear stick will almost touching the tunnel hole bit.
and i will have to remove the front diff because the clutch slave and fork will hit it. that all for now.
u13turbo
Post by u13turbo »
Its looking good man, bit more and she'll be done. You should just chuck another 1-2" bidy lift in, that'll sort the tunnel hitting issue
wax
Post by wax »
Wow you have done a heap of work, well done
passengerpete
got the box in today. there's good and bad news. the good news is the box is close to completion. the bad news is that i don't have any front suspension, and i did not want to sas it so soon, but that's life.
i had to cut open the tunnel a bit to get the box up high enough
will have to make a tunnel extension, ya may not notice it when its all finished and back together
the gear sticks are close to the dash but will heat em up and bend then to suit. ya can see here the front diff is in the way of where i have mounted the clutch slave Cly, not that it matters as it will get ripped out soon enough anyway. the clutch fork is on a odd angle so i can get clearance for pto.
now this is where it all goes pear shaped. the transfer case is in the way of drivers side torsion bar. but wait there more the rear drum hand brake is in the center of the torsion bar cross member so have no front suspension.
Last edited by passengerpete on Mon Apr 21, 2014 8:47 am, edited 4 times in total.
passengerpete
temporary gearbox cross member, its a bit rangi but will do for a few days till tom dose his thing on it.
slide
Post by slide »
Very interesting. Keep them photos coming, watching with interest :D
that4wdkid
Newbie
Newbie
Post by that4wdkid »
passengerpete wrote:put in new springs its a bit highter then i was expecting
Ha that looks like a king i like it
passengerpete
Thanks for the comments guys
I got it going today, just needs a drive shaft made to make it Mobile. apart from the front being on the bump stops. still need to sort out reversing lights and fined out what the hell the other wires are for, maybe speedo not sure. and clean up around the tunnel where i got a bit hillbilly on it with the grinder.
about the the drive shaft i read about people adding more travel in the slip joint should i be doing that too ? for future proofing maybe ? I've never had a drive shaft pull apart on me so that's why im asking. is this mod more for rock crawling truggy with super flexy axles.?
so now need some front suspension and maybe a new diff to put it on what to get is the question. might stay with the safari theme and use staged wheels
passengerpete
sent the two drive shafts in the drive shop today. to make a terrano/safari hybrid. might have to change the badge on back of car to terrari or safano shortly.
KIWI_TERRANO
Post by KIWI_TERRANO »
If you tracked down a mq patrol axle they are couple mm wider than terrano, i was going to use one when i blew my suspension apart, then get tom to do his awesome 3 or 4 link front with coil overs then it will be unstopable :)
passengerpete
KIWI_TERRANO wrote:If you tracked down a mq patrol axle they are couple mm wider than terrano, i was going to use one when i blew my suspension apart, then get tom to do his awesome 3 or 4 link front with coil overs then it will be unstoppable :)
yea that would be awesome.
the problem that springs to mind is that the mq patrol is getting a bit older these day and parts might be harder to find then say a hilux or gq, i could be wrong tho.
as for the coil overs and links. that's phase two. :wink:
i will just sas it the easy way first, and drive it
passengerpete
some more progress. cross member all finished thanks to tom,
still waiting on drive shaft to turn up. kinder thought it would be back by now tho they must be busy. im instilling a terrano manual pedal box this avo, and locating some hard lines to suit. will order a new clutch master cylinder and a new safari slave cylinder on Monday sick of pay out the ass at ripco need some hook ups lol. will make a new trans tunnel hump and that's pretty much gearbox complete, will reinstall interior after that. im a wee bit concerned that the rear drive shaft might be too close to the middle cross member to. will find out when drive shaft turns up.
as for sas still pondering the pros and cons of each axle to use. so needs more research before i tackle that one lol.
so next project will be some sliders, i got my crayon's out last night and made some plans up, i ordered some 80x6 flat bar and some 48mm tube with 4mm wall i think that might be ok to jack off ? the bar is for wrapping around chassy u shaped with gussets the tube will weld to that i got some pics i borrowed from the net of what i want to do.
tomsoffroad
Flopsie
Post by tomsoffroad »
The tube you've got for the sliders will be heaps, I recommend you simply weld them to the chassis. Mush less work than making brackets :wink:
passengerpete
to late :oops: im committed now as half started. i guess ill know for next time.
so a few hours ago when i said i need some more time and research on what diff to use and why..... well when i was out looking for clutch hard lines i kinder came home with this...
tomsoffroad
Flopsie
:lol: :lol: :lol: :mrgreen:
passengerpete
drive shaft all finished just a small problem the shop closed for Easter before i got to pick it up :(
started taking measurements of safari chassis for suspension pick up points. still might go leaf spring at this stage as will have more scope for cheap articulation. but will throw the safari stuff under it to get it rolling at this stage.
my workshop floor could do with a mo too :)
so now the removal of the independent front suspension has began.
mr Hitachi, mr dewalt, meet mr ifs
Last edited by passengerpete on Sat Apr 26, 2014 7:10 pm, edited 3 times in total.
KIWI_TERRANO
Where the like button, go colis then it coil all round and you wont regret the ride quality, remember mounts can be moved easily
passengerpete
Re: another terrano/safari project = terrari
independent front suspension is now gone just need to prepare the rest of the frame.
kiwipete
Post by kiwipete »
Well done indeed fella, I am so looking forward to seeing how this all pans out :wink:
Ph 0212078472
passengerpete
kiwipete wrote:Well done indeed fella, I am so looking forward to seeing how this all pans out :wink:
so am i :lol: there not a lot of method, in this madness :lol: :lol:
preparing the frame using a grinder is noise and dirty job might try and hire a plasma cutter.
tomsoffroad
Flopsie
Choice. Its sitting level again :mrgreen:
passengerpete
mostly prepped one side of frame and have run out of cutting disks. so will throw so pics up of whats going on or what im thinking might go on :)
this pic is the terrano chassis depth about 100mm pic was taken before i finished the frame
this pic is the safari chassis depth about 110mm im thinking i might be able to just cut the safari chassis so it slides over the terrano chassis
this pic is of the width of safari chassis where the radius rods mount. all measurements taken under and over to make centers. eg inside chassis to outside chassis
and this is about where they would sit on the terrano
not what i was expecting either lol.. so the mounts for the radius rods have to go under the terrano chassis. as opposed to beside it like the safari.
this pic is the bottom spring perch on the safari diff housing and how easy it is to move the springs in to suit the top.
