Page 4 of 5
Re: 1990 2 door disco
Posted: Tue Jun 17, 2014 8:37 pm
by muddyplumber
Any whiteish bits you see is dust/dirt in these photos
Posted: Thu Jun 19, 2014 7:30 pm
by muddyplumber
Started building side bars these will go over top of flares and mould into the side steps.
Posted: Fri Jun 20, 2014 7:48 pm
by muddyplumber
Playing round with mounting positions, will make all the side bars removable.
Posted: Thu Jul 17, 2014 7:54 pm
by muddyplumber
More photos to come.Trimmed up rear guards.Had to remove front solid flares and remount them back a bit to give more clearance. Front bar has been charged. Almost finished the bar work.
Posted: Wed Jul 23, 2014 10:29 pm
by muddyplumber
Hopefully it will be out of the shed soon, looking forward to having a clean up and getting some space back.
Have moved all the winch backwards, rear diff is now in, front pretty much in.Fitted new front springs.
Thinks to go to sort
Finish rebuilding winch
Get twin lockers fitted.
Test brakes
Driveshafts
Posted: Thu Jul 31, 2014 7:14 pm
by muddyplumber
Bit of an up date, I am hoping to have it out of the shed on Sunday so will take some better photos.
Just waiting on diff heads then I can start putting back together.
Have fitted 30mm wheel spacers now, this thing is wide and looks staunch
Posted: Fri Aug 01, 2014 11:41 pm
by muddyplumber
front finished, just have spot lights to mount
Posted: Fri Aug 01, 2014 11:43 pm
by Smurf
Are you planning on bring this over to Westport next week?
Posted: Sat Aug 02, 2014 6:56 am
by muddyplumber
Yup I am, just gotta get her back together. Spent a lot of late nights on it, just the little things keep sucking up time
Posted: Sat Aug 02, 2014 9:48 pm
by muddyplumber
It's coming together, aim is to have it ready for trip to the coast next weekend.
Posted: Sun Aug 10, 2014 11:55 pm
by muddyplumber
After some bloody late nights we got to the coast. I am really pleased with the way it's come out, gearing seems to be perfect and the big boosted 200tdi doesn't seem to be lacking in snot. Will lift rear another inch and era place front shocks.One of the issues I found were the brakes seem hard, almost like when your being towed you dont have much of a peddle, would this indicate a vacuum leak of some kind?There are afew other wee bits that need sorting but will do later
Posted: Mon Aug 11, 2014 6:23 pm
by Mattman
Looks great!
Posted: Sun Aug 31, 2014 5:56 pm
by KIWI_TERRANO
Saw you today at rolly mc d was going to come over say g'day and have a geez but you had disapeared from truck before i got out of drive thru,
Looks bloody good mate
Posted: Mon Sep 01, 2014 6:34 pm
by muddyplumber
Bugger, yeah next time you see me come say hi. Was just heading back from up the Avoca after 3 days of eating sausages maccas was AMAZING
Posted: Mon Sep 01, 2014 6:41 pm
by KIWI_TERRANO
I could imagin, thought you must have been somewhere for night was loaded to the hilt!
I was in white ranger with the bullbar etc than was in front of you
Posted: Mon Sep 01, 2014 7:08 pm
by muddyplumber
Yeah I did see ya. Yeah once it's got 3 fellas and all our gear in it she bags out a bit. Will replace rear springs with some lifted ones soon
Posted: Mon Sep 01, 2014 10:13 pm
by KIWI_TERRANO
muddyplumber wrote:Yeah I did see ya. Yeah once it's got 3 fellas and all our gear in it she bags out a bit. Will replace rear springs with some lifted ones soon
I thiught you would not many rangers out there getting set up like mine, probably should do a build thread
That lamdy has a good stance tho for the size tyres your running, low short and fat, but still gas good approach and departure angles, but i must ask soare tyre?
Posted: Thu Dec 11, 2014 5:01 pm
by muddyplumber
Bit of an up date, have done a couple of trips in it now but has been parked up for the last 2 months due to transfer case issue and not having any time to tinker with anything. Xmas is coming so perfect time to get some stuff done.
Once I had gear in the back it was sagging a lot , I have now fitted a pair of lifted 4" lifted 80 front springs in the back, time will tell if these flex like I want... I have my doubts but hey will see.
The front doesn't really flex so I am going to remove and only run one set of shocks in the front and will be fitting Superior Engineering Superflex arms.
Will be fitting a set of beadlock rims
Sorting a stereo
Fixing oil leaks
Getting some new battery's
Look into fitting rear mounted winch, I think I have room.
Posted: Fri Apr 03, 2015 6:19 am
by Mattman
Cool build. Any updates? What ratios did you end up running?
I assume you used the donor axle arms rather than fit landrover arms to the other axles?
Matt
Posted: Fri Apr 03, 2015 12:13 pm
by muddyplumber
cheers man. Truck has been out of action for 6months now, split with the wife so its now time to get back into working on it. Iv used factory safari arms in the front which have been moved forward slightly. Transfer case has been causing me afew issues and i was to lazy to pull out and rebuild so thanks to Jase ( ClassicCruiserSpares) he has tracked me down another one. These are from a v8 110 Defender and i believe these are as rare as rocking horse shit... Im running 4.1 diffs and the 36s, seems to have enough power at this stage. Flying out to aussy in an hour so will try and bring back a set of Superflex Arms on the plane.
will keep updates coming.
Posted: Fri Apr 03, 2015 12:18 pm
by Mattman
Nice!
Posted: Fri Apr 03, 2015 3:28 pm
by Crash bandicoot
muddyplumber wrote:The debate on weither or not the truck I have is actually an ex camel truck came up again when I was selling some bits the other day,I have been told its not and have been told it is by various Landrover nuts.
It may have been a support vechical....possibly.
It maybe an old shell that someone tried turning back into a camel look a like over the years.
I realise it has got bits on it that arnt the real deal etc. I have pulled the winch out and everywhere you look it's Sandglow,all mounts and body panels.Did they make a 1990 3 door Discovery that came out factory in Sandglow that wasn't intended for the Camel Trophy?
I'm just really interested to find out its history,the fella I'm dealing with at the mo is from the UK and reckons he will have an answer for me soon. On another note,I havnt welded anything to the chassie so in theory it could be converted back to Landrover diffs in the future.But for now will continue with the build. Rich
I have some news for you
I sent your pics to a mate in the UK, he came back with
"65th anniversary model, a limited pre production as a camel trophy but were not used in the event in any way as the competition ones were all made LHD."
Posted: Fri Apr 03, 2015 6:20 pm
by lax2wlg
Technically impossible, its a 1990, the company has been around only since 1948.
Posted: Fri Apr 03, 2015 6:56 pm
by Crash bandicoot
lax2wlg wrote:Technically impossible, its a 1990, the company has been around only since 1948.
Checkmate
before 1978 L/R was a division of British leyland.
That green one is Pre production which also means it's older thye actual main production model. possibly by another year or two.
Posted: Fri Apr 03, 2015 7:13 pm
by lilpigzuk
Posted: Mon Apr 20, 2015 10:22 pm
by muddyplumber
maybe your right, i still have the UK plates that came off it. It was G32 GDC
Posted: Tue Apr 28, 2015 8:21 pm
by muddyplumber
New rims, redoing front bar. Time to put everything back together
Posted: Tue Apr 28, 2015 8:25 pm
by muddyplumber
Got a wide stance now, fitted new rear springs to lift ass end up
Posted: Sat May 02, 2015 1:16 pm
by BadCo
Hey nice Disco, just wondering where you got the rims from? I struggle to find rims with a proper offset in NZ.
Posted: Sat May 02, 2015 7:36 pm
by Ralfie
BadCo wrote:Hey nice Disco, just wondering where you got the rims from? I struggle to find rims with a proper offset in NZ.
They are not Land Rover diffs under that Disco.
