Have you removed the swaybar on your offroader?
brakes-shocks-lockers-etc
Have you removed the swaybar?
Yes I have
137
66%
No I havnt
55
26%
I run swaybar disconnects
16
8%
Total votes: 208
kbushnz
Re: Have you removed the swaybar on your offroader?
Post by kbushnz »
jagni401 wrote:After thoughts on whether you'd get more flex from a LWB LJ78 Prado
Big yes for the front. Threw mine away in the first year.
Kept the rear and have made a disconnect system.
Does make a difference off road.
Shes a bit tippy on the open road, but cant help that with lift and 35's. Just drive to the conditions.... No worse that the 4x4's of old.
Calvin
Suza
Post by Suza »
I remove my front sway bar for harder trips. The rear has a factory disconect which works really well on the bighorns. If I am going on family based trip with camping gear I keave it in as I end up with 6 to 7 people in the truck and a lot of gear in the roof basket which makes it very top heavy and without the front sway bar a very scary trip :shock:
daymo
Post by daymo »
No mention here of a 90 series prado? Have IFS. What would be best? Anyone removed sway bars/added disconnects front/rear to theirs, and what was the result?
