"Jafa's Jalopy"...3RZ-FE and on 40's:)
Moved
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
I'm gonna move this to your build thread Haynzy
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Fawk!, looks like it might work!!
Max droop on this side, could get more with longer shocks
Dropouts doin their thing
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
tgaguy1 wrote:Are you going to have some way of locking the drop out rods so when you jack it to change a wheel you dont need to jack it 10 feet in the air to get the wheel of the ground? Or am I missing some of the details in this setup? By the way, very nice job, I want one.
thanks for the compliments. The easiest way to jack it up will probably to chain or strap the diff to the chassis rail before lifting, or mebbe I'll come up with a plan to use the hub....
Anyways, heres some more Hilux porn!
Got the rear hubs and drive plates finished, just about to fit an old diff head and measure up for new axles, I'll turn them up tonite and an electrode to erode the splines in the drive plates. Then setup the dividing head on the mill to spline the axles. That shuld keep me busy for the rest of the week
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Heres one with the drive plate removed
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
- MAHINDRACJ4A
MAHINDRACJ4A wrote:This is a very nice buildbig ups to you
how hard was it to put disc brakes into it ? as im looking to do the same to my mahindra cj4a
Well if you have the knowledge and the gear, its not that hard
WTF is a Mahindra cj4a??
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
A bit of progress on the axles this week
You can see the difference in length compared to a stock rear axle, this will give me 100mm more track per side.
Few pics of the spline setup and the electrode to burn the splines into the drive plate
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Built a jig for rotating the front knuckle balls today, chucked the front diff in the lathe and put some grooves in next to the factory welds, then with the help of a bar thro the kingpin holes, rotated the balls
to point the pinion at the TF case flange, then layed down a root run and will finish it of tomorrow, then its onto coilover mounts, 4 link mounts and strengthening, tho not to the extremes that Reece went
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
got three housings here that are bent from road usestrengthening, tho not to the extremes that Reece went
Damm you have all the toys Jafa "insert green with envy icon
More more
Cheers Reece
Reinforced my balls tonite
Cant see very well in these pics but the gusset is actually a piece of tube cut to fit, I'll post a pic from the top later, after its cooled down
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
With all the talk that goes on about what everybody has "flipped", i got to thinkin "What can I do on my truck that is flipped?"...How bout flipped u-bolts? ..nope, no leaf springs....how bout a flipped steering arm?....nope, got proper hi steer...Hmmm gotta be sumfing!!, then it occured to me
A FLIPPED BUNG HOLE!!!
:lol::lol::lol:
Back to the real stuff........and the strengthening begins..........
Hows this for a tube notcher
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
I know you don't want the weight I've put in mine but I'd sugest a bit of bracing from the end of the tube brace to the end of the axle tube
Its just the research I did on pirate and few other places showed there is a weak link where the swivel ball housing ends inside your axle .... alot of guys who jumped them bend em there
Cheers Reece
De-Ranged wrote:I know you don't want the weight I've put in mine but I'd sugest a bit of bracing from the end of the tube brace to the end of the axle tube
Cheers Reece
Yer its aint finished yet, the area on the ends will be stronger once i build in the coilover mounts.
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
De-Ranged wrote:thought you would... but I'd hate to see something as mean as what your doing have a simple weak link
Hey how are you going with that PTO setup.... started machining the shafts yet?
Cheers Reece
I have drawn it all up on Solidworks and it'll all fit nicely within the gap between my a340 and geardrive TF, I'll shorten the main shaft at both ends and put 23 splines in one end and 21 in the other, CNC up an alloy housing and she's all go
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
I rotated them so that the angle between the diffhead mounting face and the axis of the kingpin is 25 degrees, this will give me about 10 degrees of caster with the pinion pointing at the tf flange at ride height. Course that all changes as soon as the suspension cycles
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Ok got a bit of work done on the front end, got the coilover hoops tacked up, and the diff hangin in there...sort of.
the pipe going from the shock hoop to the diff is the length of the coilover at ride height, the one going from one hoop to the other just sets the distance.
Next is to fully weld it all and add plates and braces between hoops and chassis rails, there will also be a strut brace going in too, but that'll come later after teh motor is in.
Heres a little shot of the coilovers
Seeing as I'm not made of money, and cant afford the primo Fox's or Kings,
I'm gonna make my own.
They are based on a Rancho 9000XL which are new out. They have a 70mm body
Extended length - 920mm Compressed - 530 Nitrogen filled, not as flash as the good ones, but at 99USD each they'll do.
the coils are of a Supra, grey ones are rears and blue ones are stiff fronts 2nd hand off trademe for fiddy bux
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
