Fj40 rear discs
jumper
Fj40 rear discs
Post by jumper »
What rotors are needed to convert from drums to discs ? hilux ? what year ?
microwaved cheese on toast
sig
Jeep Jeep
Re: Fj40 rear discs
Post by sig »
sorry rob .been away with the kids since last week.i,m using hilux solid rotors because i,ve got the calipers to suit.if you use subaru front calipers (they have handbrake attachments) you will need solid rotors as well.cheers sig
Armourguard
Re: Fj40 rear discs
Post by Armourguard »
sig wrote:i,m using hilux solid rotors because i,ve got the calipers to suit.if you use subaru front calipers (they have handbrake attachments) you will need solid rotors as well.cheers sig
What type Subaru would you get the front calipers from :?: :mrgreen: would these work http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Subaru/Other/auction-139735538.htm
"Owning a 40 is almost like having an ugly child, with a really good personality."
jumper
Re: Fj40 rear discs
Post by jumper »
No problem Sig
I got a pair off a 80's leone?? or the like 1.8 4wd at the wreckers. The ones in that auction dont have the handbrake on them
Armourguard
Re: Fj40 rear discs
jumper wrote: The ones in that auction dont have the handbrake on them
And if i didnt want to put handbrake to on rear axle what subaru calipers could i use :?:
niblik
Re: Fj40 rear discs
Post by niblik »
i'd say any that ya want armourguard... just remember that the newer calipers will probably require a bit more fluid/pressure in em to activate correctly.. not 100% sure on this but i think rokhound had a little trouble with this when he upgraded his monsters brakes on the rear.... he might chime in with a bit of insight...
i'm going subaru leonie calipers.... :wink:
Armourguard
Re: Fj40 rear discs
niblik wrote:i'd say any that ya want armourguard... just remember that the newer calipers will probably require a bit more fluid/pressure in em to activate correctly.. not 100% sure on this but i think rokhound had a little trouble with this when he upgraded his monsters brakes on the rear.... he might chime in with a bit of insight...
Sweet :wink: thanks Niblik :mrgreen:
