Fj40 rear discs
Posted: Thu Feb 07, 2008 5:59 pm
by jumper
What rotors are needed to convert from drums to discs ? hilux ? what year ?
Re: Fj40 rear discs
Posted: Thu Feb 07, 2008 6:25 pm
by sig
sorry rob .been away with the kids since last week.i,m using hilux solid rotors because i,ve got the calipers to suit.if you use subaru front calipers (they have handbrake attachments) you will need solid rotors as well.cheers sig
Re: Fj40 rear discs
Posted: Thu Feb 07, 2008 8:10 pm
by Armourguard
sig wrote:i,m using hilux solid rotors because i,ve got the calipers to suit.if you use subaru front calipers (they have handbrake attachments) you will need solid rotors as well.cheers sig
What type Subaru would you get the front calipers from :?: :mrgreen: would these work http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Subaru/Other/auction-139735538.htm
Re: Fj40 rear discs
Posted: Thu Feb 07, 2008 8:26 pm
by jumper
No problem Sig
I got a pair off a 80's leone?? or the like 1.8 4wd at the wreckers. The ones in that auction dont have the handbrake on them
Re: Fj40 rear discs
Posted: Thu Feb 07, 2008 9:15 pm
by Armourguard
jumper wrote: The ones in that auction dont have the handbrake on them
And if i didnt want to put handbrake to on rear axle what subaru calipers could i use :?:
Re: Fj40 rear discs
Posted: Fri Feb 08, 2008 5:59 am
by niblik
i'd say any that ya want armourguard... just remember that the newer calipers will probably require a bit more fluid/pressure in em to activate correctly.. not 100% sure on this but i think rokhound had a little trouble with this when he upgraded his monsters brakes on the rear.... he might chime in with a bit of insight...
i'm going subaru leonie calipers.... :wink:
Re: Fj40 rear discs
Posted: Fri Feb 08, 2008 7:19 am
by Armourguard
niblik wrote:i'd say any that ya want armourguard... just remember that the newer calipers will probably require a bit more fluid/pressure in em to activate correctly.. not 100% sure on this but i think rokhound had a little trouble with this when he upgraded his monsters brakes on the rear.... he might chime in with a bit of insight...
Sweet :wink: thanks Niblik :mrgreen:
