a gen 1 surf cab.. stripped of all the crap you don't need
a gen 2 hilux double cab chassi
the rest includes a 2.8 supra motor, a set of 94 hilux solid axles
The intent is a bit against the trend
As Stephen wants to be as active as possible in this he's doing all the grunt work... grinding cutting etc, so the speed is being set by him
Starting from the ground up with the rear axle
Rear axle was swopped for an IFS axle, Filler was relocated and the pinion was rotated up a bit to help out with the shorter wheel base... the usual shave done with 10mm plate and a crown gard welded on. Then after a bit of talking he decided the axle need a bit of bracing ..... as hilux axles tend to bend just on the flat where the axle tube starts to flair for the diff head, a brace was added there, after talking to a few of the trails boys he decided it need a bit of bracing out where the bearing mounts weld to the axle tubes as well
I've also machined the axle flanges to take a disk conversion and installed a Lockrite....
After alot of talk 4.8 diffs were decided on along with a set of rock crawler gears from SNR (still to come)
Oh and new bearings thrown on as well
We're now working on the front axle.... most of the bracing has been cut and its just the slow process of welding, weld an inch drink some piss talk a bit weld another inch
While thats happening I've started to sort the front suspension.... (I'm getting old, theres only so much drinking I can handle
theres a whole lot more about to happen here yet but this is the start
Anyway more to come
