Hi guy's, i've got a 87 110 county, just started to notice a shudder coming from underneath when i pull away probably only lasts for about a meter but has me concerned.Replaced the a frame balljoint a few months ago and got rid of the clonk and now i've got a shudder, the joy's of owning an old landy.Any help would be appreciated, cheers
mike
shudder as i pull away
Re: shudder as i pull away
Could be worn suspension bushes, broken or worn engine and/or gearbox mounts, soiled clutch disc (oil on disc), broken springs in clutch disc and probably another few possibilities.
What I have learned from owning a Land Rover is that if the front left wheel is wobbly, it is probably the right rear wheel which needs adjusting.
So check carefully and start with the easy bits, suspension and engine/gearbox mounts.
Thanks cloggy, i'll check those things out in the light tomorrow.cheers
mike
mike
are you a member of the yahoo group of nz landrover owners
they are a huge wealth of knowledge were great when i owned my landy but since then i have seen the light and it is a 3 pointed star lol
my 4wd is not a truck
- Fish13
- Driver/Navigator
Hi,
I've had this on an old Series and it was the propshaft UJ's that were badly worn and causing some slack. The judder at low speed was the propshafts 'wobbling' and when at higher speeds the force took up the slack and no judder. Cam on all of a sudden as well, not over a long period of time.
Worth a look?
Worth a look?
1988 Range Rover Classic 3.5V8 EFi
