Carbie solution needed
For all Suzuki related topics
moonhopper
Post by moonhopper »
i'm still trying to wrestle with the problem of what carb to fit to my trials truck i've been quoted all sorts of options but they all need adaptors and mods to make them work and at the end of the day i'm no farking mechanic so i have been on the ausie site and they seem to bee keen on there weber carbs, but they have a guy on there using the
corolla 4k carb it seems to bolt directly to the zuk manifold, anyone using this type, i'm really trying to find the best solution to my carb problem and will give most types a go that are uncomplicated :mrgreen: sugestions, diagrams, photos wellcome
i'm hopeing to have the truck at the Napier round for its first outing.
jimnykriket
Newbie
Newbie
Re: Carbie solution needed
Post by jimnykriket »
I guess you have a 413 engine? I have a manifold with throttle body injection on it that will bolt to your head, easiest and best way to fix any carb, comes with loom and ecu to run it. I'll even label the loom for connection, $650.
moonhopper
thanks for the offer, if was at the satrt of the build i would have said fantastic, but i'm at the end with the money running low, if i can find some extra coin i will give you a pm. cheers
Return to “Suzuki”
