23rd and 24th Feb
curly12
23rd and 24th Feb
Post by curly12 »
Well great start to the weekend. Last night Taz01 and Turoa helped me pull the head off the 2f in my cruiser.
Something was amiss last week, when on the way to fuel-up to head into Rallywoods, the cruiser died. She was pumping huge amounts of steam out the exhaust.
Anyway a quick compression test last night showed no1 and no2 cylinders with no compression. Off came the head and no1 cylinder has blowen a 20mm gap in the gasket leading into the waterjacket and no2 piston has a hole in it.
Quick call to the Beer-Brother's and a replacement engine is on the way :D :D
Now to swap them over.......
Re: 23rd and 24th Feb
I thought the V8 was going in Curly :roll: what about Saddams 302 when his 350 goes in :twisted:
Jerry wrote:I thought the V8 was going in Curly :roll: what about Saddams 305 when his 350 goes in :twisted:
*Correction Jerry :wink:
the safari went staight through its wof, handbrake needed ajusting , change back to the 33'' when its stops raining
wopass
Post by wopass »
Jerry wrote:I thought the V8 was going in Curly :roll: what about Saddams 302 when his 350 goes in :twisted:
sadam would never have a ford anchor in his cruiser ! how dare you even sugest such things, i think for your sake you should appoligise imediatly !!! :P
taz01
Tazzles
Post by taz01 »
after much moving and placing until i was happy the power steering box in my 40 is in yet to run hoses but its in so i can now move it off the front lawn much to other half's approval .........something about lawn is dead under it blah blah blah :lol:
will go give curly12 a hand thisavo .
WARNING:
xj
Post by xj »
1)Took the sand tyres off, put the mud tyres on.
2)made brackets to tie the recovery hook mount to the new rear bar to the rear x-member to the chassis. Everything is now well hooked together. viewtopic.php?f=32&t=9839&st=0&sk=t&sd=a
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Shane
Post by Shane »
You can get a 302 chev,one of the guys at my old work run one in his holden LJ drag car was a strong we motor.I wouldnt use a 302 Ford in a cruise either,might be a bit much for it :shock:
Shane
85BJ73
Post by 85BJ73 »
Got 2 missing bolts in winch bar (never trust a mate who doesn't appreciate this type of thing), fitted two rated tow hooks to winch bar in place of standard Toyota ones, fitted new greasy nipple to front drive shaft yoke, checked and loaded recovery bin into back of 'cruiser in anticipation of tomorrows trip. :D
No matter the problem, the answer is always give it more gas.......
Modded 1985 Landcruiser, semi restrained nutter behind wheel.
hosehustler
Post by hosehustler »
Had a great weekend out crawling arond the Canty alps....but then....oh bugger :o
Nothing that can't be fixed either going to do a body swap or repair, either way I was lucky, to come out with just a few cuts and scratches, think I will do the exo i've been gassing on about......before I head out again :roll:
I hate signatures
SMOKEY
Post by SMOKEY »
Och, Tim glade to hear your OK, Surf looks very second hand, would have to be a rock right where you planted your A pillar.
There's one thing about you Tim, your a bloody battler, and I'm sure this hiccup won't stop you for long. Any way you where starting to run out of things to do to your vehicle, so now you have got more than you bargained for. :cry: .
MAYBE YOU SHOULD STAY WITH THE MUD TEAM, THOSE ROCK BOY'S PLAY TO ROUGH,
FITZY.
tintin
Post by tintin »
gave the surf a 25mm body lift and made some sliders to bolt on the chasie, and off to the kaimai trials tomorrow
Shane
Post by Shane »
hosehustler wrote:Had a great weekend out crawling arond the Canty alps....but then....oh bugger :o
OUCH thats bad luck with that big barstard rock in the wrong place
MATT4U
Post by MATT4U »
just need a roof a tim
Smurf
Post by Smurf »
OW!
What a bugger Tim, Hey if you are after a body try Nstg8a on here, he may have an IFS body you could grab, if he hasn't dumped it yet. He is Nelson if you don't mind a short drive.
Chopper01
Rock God
Post by Chopper01 »
Na it's only a scratch it will buff out :wink: :lol: :lol: :lol: :lol:
but job well done tim :mrgreen: :mrgreen:
rokhound
Post by rokhound »
Make that 2 surf bodies. After Tim left, I lay my pos shit down on a private shingle road after avoiding another truck that locked up in front of me. Was only doing 40 cliks, but managed to do almost as much damage as Tim, and if I had not had the exo (which is now buggered) I am positive there would have been some very serious injuries, and possibly even worse :shock: .
As it is there are a couple of very sore bodies at the moment, and 1 very lucky Rok pup who pretty much came away unscathed.
Still can't believe how quick we went sideways up the bank, it happened in a flash. We then slid 10 - 20 feet down the road before stopping. And it was my second flop for the day as well :lol: . 1st one took for ever to go over, and exo did exactly as it was designed to do, (shame I didn't design it to handle bigger impacts :roll: :roll: )
Still, I need a new surf roof section or entire body as well. :wink: :)
Smurf
Post by Smurf »
Chopper01 wrote:Na it's only a scratch it will buff out :wink: :lol: :lol: :lol: :lol:
Anything will buff out with a big enough grinder eh.??
dazza85
Post by dazza85 »
rokhound wrote:Make that 2 surf bodies. After Tim left, I lay my pos shit down on a shingle road after avoiding another truck that locked up in front of me. Was only doing 40 cliks, but managed to do almost as much damage as Tim, and if I had not had the exo (which is now buggered) I am positive there would have been some very serious injuries, and possibly even worse :shock: .
Do you have any photos ??
UBZ
Post by UBZ »
tintin wrote:gave the surf a 25mm body lift and made some sliders to bolt on the chasie, and off to the kaimai trials tomorrow
Can fit those 35"s know Tintin :wink: :wink:
Chopper01
Rock God
Post by Chopper01 »
now your learning smurf :mrgreen: :mrgreen: :mrgreen:
Yea it was a good day out crawling , pitty we missed tims roll over on a camera but it nothing that cant be fixed(as I said tim I've got doors and guards you can use) then thinking that was the most carnage that could happen when we saw what happend to rok from behind as he slid into the ditch sidways and then saw matts head hanging out the top of the cage I thought it was going to be alot worse than what it was. But I'm just glad that rok , mitch and matt were all right and thats the main thing.
rokhound
Post by rokhound »
dazza85 wrote:Do you have any photos ??
None of it on the side in the middle of the road. There was fuel pouring out of my POS and the boys had it recovered really quickly. These couple of pics are just of the damage.
The damage may not look too bad, because the exo took the brunt of it (as it is supposed to), but my cage was not designed for impacts of anything over 1kph :roll: (as that is all we need). The roof is pretty well pushed over and in, and the passengers door opening is out of line by about 50mm.
Just put it on the list, I also munted a 30 spline longfield cv earlier in the day :roll:
Big day out, but it was all good shit, until it started going pear shaped :lol: :lol:
H2OLOVA
Post by H2OLOVA »
Jeez Rok that sunroof glass has only done 2 trips since i fixed it :roll: Did Mike get much video?
rangimotors
Post by rangimotors »
shit guys feel sorry for ya's, but glad everyones ok. Let me no if someone wants a surf body, it was a solid axle 85 ish surf,, now its just the body with no doors or front end. I'd have to check but last time it was free to a good home. Let me no if it would be any help and i can find out more details
madaz068
Post by madaz068 »
Good to hear that your ok Tim.
IcedJohnno
Trailer Trash
Post by IcedJohnno »
Well I cant compete with the boys playing in the Alps :shock: :oops: :D
hope all is well guys.
Matt from my experience with major bangs on the noggin I would head to the DOC ASAP. Sometimes concussion can haunt you for a lot of months to come,....
Well Friday night I used my rig to move into my own house. :D :D Yay!
Has only been 10 years in the making (trying to find the right place) and 11 days after I did the deal i am now living there :D
Oh and did i mention the garage, tis rather large :lol:
wopass
Post by wopass »
well i went fishing again :mrgreen:
nice
Suza
Post by Suza »
Got the new radio in just need the ariel and it's all done and started work on my new drawer/storage unit for the back of the Bighorn
TJ
Post by TJ »
IcedJohnno wrote:Matt from my experience with major bangs on the noggin I would head to the DOC ASAP. Sometimes concussion can haunt you for a lot of months to come,....
I agree, glad you guys are okay. But do get a check-up done. I had an accident and didn't think of it. Started hurting me a week later and I sometimes still pay for it six years down the road (issues with my back bone).
basics
Post by basics »
holy shit rokhound, lucky you had a cage! :shock:
99 pajero exceed 3.2
