timing specs for a 3Y
Posted: Mon Feb 25, 2008 7:42 am
Does anybody have the timing specs for a 3Y?
Tony
Tony
The opinions and viewpoints expressed by users of Offroad-Express Forums are wholly their own and not necessarily those of Offroad-Express.
https://www.offroadexpress.kiwi:443/Forums/
https://www.offroadexpress.kiwi:443/Forums/viewtopic.php?t=10241
muddyhilux wrote:hi tony
8degrees BTDC @850rpm
firing order 1342
pistons counted 1234 from radiator backwards
#1 on dizzy is at 9oclock position looking from front and goes clockwise
anything else ya need
wopass wrote:muddyhilux wrote:hi tony
firing order 1342
i would go for 10deg and run BP ultimate...... but you forgot to mention the vacume advance hose off and pluggedand 0.016" points gap (better than the recomended 0.018" as it helps them rev a bit better)and if you want a really good fat spark use a 6volt coil and carry a couple sets of spare points and condensor
