Lucas 4CU ECU
jdeburgh
Lucas 4CU ECU
Post by jdeburgh »
I don't suppose anyone has a sapre Lucas 4CU ECU hanging around have they??
Thanks
John de Burgh
Cloggy_NZ
Texas Chainsaw
Re: Lucas 4CU ECU
Post by Cloggy_NZ »
I think 91Rangie has. Mentioned it to me once. Send him a PM. Could be a 4cux though.
Re: Lucas 4CU ECU
PM andic ....he has 50 rovers in parts at his place :lol: , can PM you his email and ph no if you want
91Rangie
Re: Lucas 4CU ECU
Post by 91Rangie »
Got a Hotwire maybe know where a Lucas one is how much you wanna pay for one?
jdeburgh
Re: Lucas 4CU ECU
Post by jdeburgh »
Jerry wrote:PM andic ....he has 50 rovers in parts at his place :lol: , can PM you his email and ph no if you want
That would be great Jerry, sorry about the late reply i have been so busy woth work and courses latley!!
Howz things??
John
-Vehicle: Rangie - 4 Wheels, 3 doors, Engine, Gearbox, other whirly bits, Steering wheel, Radio, Seats, Pedal that makes noise, pedal thats stops it, and pedal that helps stop the crunching noise when using the gear lever.
http://www.feilding4x4.org
Re: Lucas 4CU ECU
Otherwise I could steal the one off Cloggys disco ..... :lol: I'm sure he won't notice :twisted:
jdeburgh
Re: Lucas 4CU ECU
Post by jdeburgh »
Jerry wrote:Otherwise I could steal the one off Cloggys disco ..... :lol: I'm sure he won't notice :twisted:
Now theres a nother option!!
Tee hee
Re: Lucas 4CU ECU
He would just assume that it fell off (being a rover :lol: )
jdeburgh
Re: Lucas 4CU ECU
Post by jdeburgh »
After a bit of tinkering and swapping and moving bits, it lives!!
Cloggy_NZ
Texas Chainsaw
Re: Lucas 4CU ECU
Post by Cloggy_NZ »
Just read this....
You cheeky buggers.
Keep your hands of my Rover :twisted:
jdeburgh
Re: Lucas 4CU ECU
Post by jdeburgh »
Just read this....
You cheeky buggers.
It's Ok Clioggy. you can relax, it's all fixed now!!
John :twisted:
91Rangie
Re: Lucas 4CU ECU
Post by 91Rangie »
How did that throttle sensor work John?
jdeburgh
Re: Lucas 4CU ECU
Post by jdeburgh »
Works well Paul!! Thanks!! Just changed the plug all the rest is the same.
John
