8th & 9th March
Posted: Sat Mar 08, 2008 3:56 pm
by xj
Cut the bottom hoop off my bar and added a bevelled plate in its place. Re-fixed spotlights so they no longer protrude forward of the top hoop. Did a TJ and painted my headlight trims black. (last week fitted the contentious Quadratec soft top too.....
Might just go and do some "then" and "now" pics on the Jeep section.
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 5:09 pm
by RJ
Looking very smart champ.
I'll do Cleveland next week and then look at desiging me a new front bar we can get into, now that you have gained all that experience on yours. Have just sorted aerial and put seperate switch in so that you can drop the thing independently.
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 5:51 pm
by 85BJ73
Painted new rims in preperation for new tyres to be mounted
, Greased suspension pins. Washed the truck too!!
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 6:39 pm
by coxsy
due to lack of use my truck was a nonstarter this morn on charge again
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 8:37 pm
by wopass
worked satday to pay for more 'cool' chev stuff for the cruiser
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 9:18 pm
by mercutio
wopass wrote:worked satday to pay for more 'cool' chev stuff for the cruiser
what cool chev stuff do you have in mind
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 9:47 pm
by TJ
Greased all the hinges (some of them were becoming squeaky).
Fixed the locking mechanism on the tail gate. Had to actually open from the inside after removing the cover (good thing its easy to access from the inside). Then improvised a couple of thick wires to imitate the factory levers which were bent. Now the tail gate locks and unlocks as it should. Don't know how the originals were bent, but it happens I guess.
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 9:54 pm
by xj
Sorry... OT....
Hiya TJ, Dont suppose you know of anyone thats got the metal strip for the bottom of the softtop rear window? Kinda got a channel running through the centre, slides on over the plastic round strip on the bottom.
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 10:14 pm
by TJ
xj wrote:Sorry... OT....
Not off the top of my head. I do like your new look front bumper.
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 10:19 pm
by xj
TJ wrote:xj wrote:Sorry... OT....
I wanted to take it further back to fully cover the steering box, but in so doing would have blocked access to the bottom 2 bolts on the bottom of the bar/chassis. The solution would have been to then drill access holes, but im figuring that might have looked a bit random.
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 10:24 pm
by TJ
xj wrote:I wanted to take it further back to fully cover the steering box, but in so doing would have blocked access to the bottom 2 bolts on the bottom of the bar/chassis. The solution would have been to then drill access holes, but im figuring that might have looked a bit random.
Now that you can weld, may be time for an engine skid?
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 10:48 pm
by xj
TJ wrote:Now that you can weld, may be time for an engine skid?
LOLROFLMAO..... i wouldnt put the metal bonding that i manage to achieve into the realm of welding, for fear of annoying those who actually know what theyre doing.
If you get far enough off the ground, you wont need an engine sump skid plate pal....
Re: 8th & 9th March
Posted: Sat Mar 08, 2008 11:50 pm
by mike21
wired up my new winch, remounted front grill with the almighty zip ties which replaced dodgy silicone. removed aircon pump to find my replacement one is wrong, GRRRRRR
THANX MURPHY!!!! and polished 1 panel bak from near pink to red. gona go watch the winch challenge boys at the kumeu show tomoro
Re: 8th & 9th March
Posted: Sun Mar 09, 2008 9:03 am
by coxsy
sunday morning truck on charge for over 12 hours still no start, think the alarm has cut in the inhibitor will not let it start ,no life or resonse with the remote pretty much screwed now
Re: 8th & 9th March
Posted: Sun Mar 09, 2008 6:47 pm
by meece4x4
spent Sat rewiring my Runva winch after it stopped working, the Winch itself was fine but the cheap plastic box they use to hold the reay and on/off switch is crap, it allows water in and my switch had corroded after only 3 months on the Daihatsu, so i removed the relay and rewired it under the bonnet in a more waterproof box this time.
oh i found out it wasnt working after some dickhead at work decided it would be a laugh to di-engage the clutch and wrap my winch cable around and around the Feroza 10 minutes before knock off on Friday night. normally it wouldnt worry me but it frigging hard to drive through town with 35 meters of 10mm wire rope rapt around the bumper..
Re: 8th & 9th March
Posted: Sun Mar 09, 2008 6:51 pm
by 85BJ73
Installed new front disc pads, finally got grease into swivel part of drop shackels
Went for a 3 hour drive in local beach/forest.
Shane
Re: 8th & 9th March
Posted: Sun Mar 09, 2008 8:55 pm
by gimmemud
went for a good play on Saturday pulling out a safari the whole time and got to use my new winch on him too which works a treat
. unforunately got 3 new dents and a busted tail light, but hey it was all fun. changed my drum shoes today and now have a handbrake again
Re: 8th & 9th March
Posted: Mon Mar 10, 2008 7:25 am
by wopass
mercutio wrote:wopass wrote:worked satday to pay for more 'cool' chev stuff for the cruiser
cant say.....
come to the last round of the laurie sansons and you might find out
Re: 8th & 9th March
Posted: Mon Mar 10, 2008 9:49 am
by pagar
Well I had a horrible weekend under and in my truck cutting out all the rust and plating it for a WOF so will take it in today which means I can move it out of my shed and put my new one in to start new build. will be going hard this week installing body lift kit, anti inversion shackles, spring upgrade putting in LSD rear end and building rock sliders and side panel protection bars. not much really... oh and a 12v power system for the toys, recovery gear holders and rack for dive bottle , air comp and tank... basically going to try to build a whole truck in a week. no worries.
Re: 8th & 9th March
Posted: Mon Mar 10, 2008 10:20 pm
by muddymatt
Went down to Auckland to collect the Range Rover. Got and drove back no problems.
Checked it over Sunday and stuck it in for a WOF today - passed!!
Now I just need to sell the Audi so I can buy some tyres for it......
Cheers Muddymatt
