need pto part
need pto part
I am after a front universal for a toyoto PTO mine has a damaged yoke on the pto side where the sheer pin goes due to the yke not sliding up the shaft it has worn the inner yoke where it goes over the worm drive. 021 438 519 if you can help or point me in the right direction. cheers
If you follow me in the bush you must be mad cause I'm plain CRAZY !!!
1987 BJ74, 13BT, Auto, 35" Wranglers, 80mm Suspension Lift, 2" body lift, LSD rear, ARB Front Locker, PTO, Lots of Steel and a Go Hard Driver.
