BALL JOINT SPACER
BALL JOINT SPACER
WONDERIN IF ANYONE KNOWS WHERE TO GET HOLD OF BALL JOINT SPACER FOR A 92 SURF, IN NEW ZEALAND, ALSO ARE THEY LEGAL WITH A CERT, I KNOW THEY USE THEM IN OZ AND THE STATES BUT THERE REGS ARE FAIRLY DIFFERENT. HAS ANYBODY HAD ISSUES WITH A 50MM BODY LIFT????????? CHEERS
Re: BALL JOINT SPACER
hi
give(Kev) worzel a PM he has body lift and ball joint spacers,
vince
vince
OH CHEERS MAN. MAT
Just got some ball joint spacers put into my surf and yup they're legal with a cert. If you have to cut or modify the A arm in anyway then defiantly talk to the cert guy first, mine wanted to take pics before and after and wanted a letter from the engineer that did the work!
what size did you use, did you have to space your diff and sway bar, iv read that they put stress on cv joints due to excessive angle
i member some one saying that you can put a 1'' spacer or washes in the front rear diff mounts?,
Can some one confirm this?
And i have just receved my body lift from Taz01 on this website,
- muddyhilux
hi jase,can confirm this is true as ive done it to my rig,and does do a good job returning the c.vs to better angles
Thanks for confirming
wot size spacers are best applied
have a look at this site
http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
alot of useful info on ball joint spacers and Diff drops
LR110 ..... LJ50 project
