Page 1 of 2
easter weekend 08
Posted: Thu Mar 20, 2008 1:24 pm
by wopass
well im gonna start it off early as im going away for the weekend and wont be back till monday
heading up to stony bay (top of coromandel,ish) to do some camping and fishing etc.
see you all in a few days
Re: easter weekend 08
Posted: Thu Mar 20, 2008 4:23 pm
by mercutio
i had lots of plans for the g this long weekend but they have all gone out the window
springs won't be ready till next wednesday
and the engine parts i ordered haven't arrived yet
so looks like i might have to go up thommos
i guess i can make a start and pull the old motor and trans out
Posted: Thu Mar 20, 2008 9:49 pm
by TJ
Today:
Got my new axle seal and bearing put in today.
Got the WoF as well.
Got them to do a full drain, flush and recharge of the brake system (new fluid). Just as a safety precaution as it was 7 years old now and might have absorbed some mositure over the years.
Nearly finished with installing a switch in the cab for the compressor under the hood.
Tomorrow plan on doing:
Finish wiring the switch.
Engine oil change.
Install new deeper transmission pan with new filter and trans oil.
Regrease everything I can get my hands on.
Posted: Fri Mar 21, 2008 4:55 pm
by Ryan
i pulled my rattling engine out today and took wireing diagrams to the mechanic whos doing the new motor....
new motor already 90% done!!!
glad i didnt give it a go myself.......
Posted: Fri Mar 21, 2008 8:39 pm
by TJ
TJ wrote:Tomorrow plan on doing:
Engine oil change.
Got 3 out of 4 done. Then kids decided it was time to go to the beach!!
Posted: Fri Mar 21, 2008 11:37 pm
by yorick
Finally got the brush screen and front bar finished on the Paj
and finished the back bumper as well mainly to protect the vulnerable part of the fuel tank, the seam. Also the 2 inch thick walled tube strengthens the chassis during those hard core snatches.
Also fitted new tie rod end, bottom wishbone balljoint, inner CV, front brake pads and Aisin freewheeling Hubs.
All in all, all ready for Tommos this weekend! Bring it on!!
Posted: Sat Mar 22, 2008 7:01 pm
by haynzy
well i got my cert on thursday arvo ready to go to rallywoods and then after only one piddly hill decent (psycho) and an attempt at a little hill climb i blew my cv to smitherines and that was the end of my wheelin
Posted: Sat Mar 22, 2008 9:48 pm
by suzolla
Got some longfields that will solve that problem, either just some 27 spline CV's or some 30 spline Supersets.
PM me if interested with your ph no.
Thanks
Tim
Posted: Sun Mar 23, 2008 7:52 pm
by niblik
worked, worked, worked and ummmmmmmmmmm oh yeah... worked!!!!
Posted: Sun Mar 23, 2008 8:19 pm
by mercutio
Posted: Sun Mar 23, 2008 9:37 pm
by muddyplumber
was on call for the long weekend so havent done much.the bighorn crapped out last weekend, just wouldnt start
and traced the problem to the crank sencer so finally got round to pulling the crank off and replacing that.was dam good to hear it start once again
Posted: Mon Mar 24, 2008 1:57 pm
by meece4x4
Our landlord bashed on the door early Friday morning and asked if we could do him a big favour, he wanted to mow some of the back paddocks but the high winds of late had bought down tons of debris and limbs, most too big to safetly run over, so we saddled up the 4bies and headed up to tha back blocks of the farm and strarted cutting, winching and dragging gum and totora limbs here there and everywhere, generally having a ball and spending a lot of time driving narly little hazzards and whatnot.
as you can see the back of the farm is quite flat and really not too much of a challange to drag the 2 foot limbs around.
and yes the left front wheel IS chocked ... no way im risking my kids with just the handbrake on that much of an angle
Posted: Mon Mar 24, 2008 6:36 pm
by rayndeb
Changed Brake pads in front.Discovered wheel bearings shagged.. Discovered brake rotors too thin ..Replaced it all good thing ive got a mate who works a parts place..The mark up on some stuff is unreal..Got wof just need to adjust hbrake.. Sweet ready for my river run now .. 2 weeks to go ..Should be awsome.. Got a thread on planing a trip have a look and come along ..
Posted: Mon Mar 24, 2008 8:40 pm
by spanky
had a good bush trip with some mates, managed to put scudo on its side again, 10 hrs of thrashing the jeep and then when driving it home from mates in the morning the cambelt broke
,lucky not a interference motor
,belt had done 3230ks since i did it which for me is about 3.5 yrs, so not to bad ,new belts and im ready to go again,
vaughan
Posted: Mon Mar 24, 2008 9:17 pm
by downunderxj
Took Jeep up Akatarawas and along Odlins Road to check if the new Crankshaft Position Sensor had fixed the problems I had over Christmas. An uneventful trip all the way into the tank traps, so it all looks good. Now I can get back out on some trips again.
Posted: Tue Mar 25, 2008 8:20 am
by UBZ
Had a productive weekend.
Fixed all the rust in the Zuk , installed new Cam belt , adjusted tappets, timed and tuned engine and finished painting up the interior ready for hippo liner and a WOF .
Was very happy until I was driving home from my mates place and dropped a cylinder.(and gained a knock)
Checked coil , leads , plugs all ok.
Know have to drain the oil and check for metal , drop the sump and possibly take the head off. Looks like it is going to be a re-build
Posted: Tue Mar 25, 2008 9:54 am
by tracta
picked up the (new to me) landrover - had some hairy moments going over the 'takas, friday played rugby and got smashed, saturday and sunday chopped firewood - I am so over it now. monday - welded up one side of the trailer, do the rest of it tonight hopefully and then start looking for some plywood for the deck.
I feel like I need another 4 days off to recover, and do all the things that I ran out of time to do
Posted: Tue Mar 25, 2008 10:52 am
by lneil
Went for a play up the Maungatapu, found one of the front hubs wasn't engaging so stripped it down and lubed it up temporarily.
On the way home had a nasty vibration that got worse and worse, I think its a UJ going out. Rear diff also seems to have a stuffed bearing, So: no more 4WDing until those get sorted out.
Posted: Tue Mar 25, 2008 11:36 am
by pagar
Went down to Whirinaki for a full on weekend of bush 4 wheeling with members of the Manukau, Taranaki, Auckland and Rodney clubs. Managed to get the new truck finished enough to take it out and it ran really well am quite happy. Bull bar #1 was not up too the task though so will have to build a new one. side bars worked a treat (just need to finish the bits that go over front and rear gaurds) and once I did some adjustments and found low gear it charged up the hills with the new 35" tyres. Found a couple of old tracks that have not been used in years deep into the place and other than that the usual tracks (hydro rd etc) are in quite good condition due to the lack of rain but would say to you guys to start using them more as the are beging to get over grown. was nice to get through new tracks and get a good look in some nice weather, it is a totally different place in the wet.
Sorry you could not make it down Coxy you missed out on some nice trails. heaps better than last year.
Posted: Tue Mar 25, 2008 11:39 am
by Smurf
Went up the Leatham valley for the weekend with several mates, spent three days 4wding and motorbike riding, the kids had a blast. Now have two quads and a dirt bike needing repairs.
Posted: Tue Mar 25, 2008 12:02 pm
by Suza
Went to the west Coast with some mates and had a blast, but did suffer from a few new injuries to the bighorn
Did the alternator in a mud hole on the Densten track on the first day so then spent a few hours pulling it out and fixing it that night at reefton. Lost the speedo on the second day which put the auto in to safe mode so no overdrive. had a go at fixing the speedo problem yesterday and no joy so its booked in to have that looked at and the auto serviced. Blocked the radiator solid with mud so that came out and has been soaking and getting washed out which was lucky because when I went to undo the bottom hose I noticed a very large bulge in the hose so have got another one being sent up today.
At the end of it all though it was well worth it saw some new country. Kept up with the Cruisers and the Jeep expect were the rutts got just a bit too deep for my 31's and had a heap of fun
Posted: Tue Mar 25, 2008 3:22 pm
by kiwipete
yorick wrote:
Id like to see some more pics of this please and the construction etc as it's something along the lines of what i'd like to do.
Posted: Tue Mar 25, 2008 3:35 pm
by kiwipete
Spent the weekend down Wanaka way with another club.
We drove this area on Saturday; Nevis Rd, Duffers Saddle, Old Woman Range, Old Man Range to the Olelisk and then down to Symes Rd at Fruitlands. We got to around 1745m altitude.
Unfortunatley the weather was not that good as there was a heavy fog until after lunch so the views were not the best.
Sunday we drove up Mt Burke getting to about 1450 meters altitude. The sights were unbelievable.
This is my first time in this area and I for one will definatley be back.
Posted: Tue Mar 25, 2008 4:36 pm
by surf_tomo
kiwipete wrote:Spent the weekend down Wanaka way with another club.
Magic part of the country, was neer there myself over easter, did the nevis road and carricktown track on moterbikes and 4wds. best part was it had rained the night before...
Posted: Tue Mar 25, 2008 4:51 pm
by Rory C
This weekend I started with a rolling chassis and got to finished vehicle stage and now I am knackered and sore
Posted: Tue Mar 25, 2008 5:37 pm
by Jezza
Spent 3 days camping at Nelson creek. Managed to do a bit of 4wding aswell, 4wding on the coast is bloody awesome!
Posted: Tue Mar 25, 2008 5:44 pm
by yorick
Most of what was done is here:
viewtopic.php?f=24&t=9443 Ask away if stuff isn't clear
Posted: Tue Mar 25, 2008 6:59 pm
by Pico42
As did we, but went to Mt Bee on the friday as well. The views from Mt Burke were amazing - we took some 200 photos!
Now the Vitara needs a new muffler, and a lift...
Posted: Tue Mar 25, 2008 10:17 pm
by kiwipete
Pico42 wrote:kiwipete wrote:Spent the weekend down Wanaka way with another club.
Pity I diddnt know you were doing something on the Friday as I would have joined in with you. I diddnt get to take too many photos as I was too busy driving.
Posted: Thu Mar 27, 2008 3:46 pm
by NJV6
