overdrives 90s
Posted: Sun Mar 23, 2008 3:34 am
by Graham Vasey
Hello I have a 2.5 petrol 90 with a 1:4 transfer box. Trying to find ways to get a better mpg without having to replace the engine with a diesel. Been looking at overdrives but I am on a bit of a buget. Is there any second hand od's which will fit, or can be modified?
Graham
Re: overdrives 90s
Posted: Sun Mar 23, 2008 5:28 pm
by Ralfie
An overdrive for a 90 would be very rare and if you did find one then bloody expensive.
For better road gearing use a 1.22 ratio transfer case from a Discovery or Range Rover. Low ratio still same as your current one but is geared slightly higher for the road.
Re: overdrives 90s
Posted: Sun Mar 23, 2008 10:25 pm
by 91Rangie
Have a look at this website for ratios http://www.expeditionlandrover.info/gear_ratio.htm
Going by that website info your transfer box has been changed should have a 1.67 in it
You could also change diff ratios
Re: overdrives 90s
Posted: Tue Mar 25, 2008 12:27 am
by Graham Vasey
Cheers guys, I'll have to start looking round some breakers yards
Graham
