THis is off a 1989 110 V8, but will fit a Series 3 or later Defender with minor mods. It is ideal if you are upgrading your Series to V8
The top half is good even under the screen mounts. The centre is good and the box section from the chassis mounts to the top section is good. The footwells are less good and would need a little mig work to pass a WOF. I swapped this one out because I needed to pass an import certification.
A new one is 1400 dollars.
Any questions, please post and I will get back to you this pm.
