Toyota 'Ute' Dilemma
Posted: Thu Mar 27, 2008 8:51 pm
by Dick
Ok, so my bro wants a new ute, or to be more correct, a HILUX. Anyway, we have been looking around quite a bit lately, and they just seem so expensive, and anything that’s in our price range has kms through the roof.
The main reason he wanted a ute is because it needs to be 4wd (for hunting, the odd farm track, paddock etc) and it has a deck for his trail bike. However, it’s only twice or 3 times a month that he actually goes out trail riding, so towing a trailer those times wouldn’t be that much of a big deal as he does it now anyway.
That leads me to this. For the mean time, (until he has been working for a while and got enough moo-la for a nice Ute) maybe a Toyota surf or something similar would do.
Therefore, my question is... are the surfs any good for the above??? We would love a 3L one, but I think once again, they would be a bit expensive for now. So therefore it seems the 2.4 may be the cheaper option.....BUT, is it 'likely' that after buying a 2.4 surf with 200,000kms on the clock, we will end up spending 3g on the engine in the near future, due to the 'incidents' that commonly occur with these engines? Or would it be better to spend that little bit more and go for the 3 litre?
Any ideas on this would be great thanks guys!!
Re: Toyota 'Ute' Dilemma
Posted: Thu Mar 27, 2008 8:56 pm
by skid
ring Klem and see if pricey still has his lexus surf for sale
you could pick it up for about 7-8k and can play with it and tow with it and it looks cool and sounds even cooler
Posted: Thu Mar 27, 2008 8:58 pm
by Dick
skid wrote:ring Klem and see if pricey still has his lexus surf for sale
Dont tempt me.......I would love that truck, however at 1.779c per Litre, mmmmmmmm.
Cheers anyway.
Posted: Thu Mar 27, 2008 9:14 pm
by skid
Dick wrote:skid wrote:ring Klem and see if pricey still has his lexus surf for sale
Cheers anyway.
diesel not much cheaper and then you have to pay a $100 a year more for rego and road users etc etc
very tempting
Posted: Thu Mar 27, 2008 9:32 pm
by Jerry
Skids orange thingy is still for sale ....just duct tape the bikes hillbilly style to the bonnet
Posted: Thu Mar 27, 2008 10:18 pm
by SupraLux
personally I wouldn't let the KM's on a Hilux worry you, as there is bugger all to break, they are a very simple little truck. Yes you can spend money on them, but if it looks and sounds ok then it probably is. Check for smooth gear changes (well, not too rough anyway), make sure there isn't gobs of oil and grease pouring out of the inside of the steering knuckles, check the engine isn't too smoky and what else is there? bugger all... make sure the 4WD works ok tho... check the hubs engage and disengage without too much drama and that everything spins as it is supposed to. Would also pay to grab the driveshaft by each diff and push it up and down to look for play in the pinions cos a blown diff will just make your day...
Best bet if you aren't sure, get it AA checked, don't think they are too expensive and they are pretty thorough.
Steve
Posted: Fri Mar 28, 2008 7:40 am
by Dick
SupraLux wrote:personally I wouldn't let the KM's on a Hilux worry you, as there is bugger all to break, they are a very simple little truck. Yes you can spend money on them, but if it looks and sounds ok then it probably is. Check for smooth gear changes (well, not too rough anyway), make sure there isn't gobs of oil and grease pouring out of the inside of the steering knuckles, check the engine isn't too smoky and what else is there? bugger all... make sure the 4WD works ok tho... check the hubs engage and disengage without too much drama and that everything spins as it is supposed to. Would also pay to grab the driveshaft by each diff and push it up and down to look for play in the pinions cos a blown diff will just make your day...
Steve
Thanks for that Steve, it has really put things in perspective.
Dick.
Posted: Fri Mar 28, 2008 9:00 am
by gimmemud
get an old surf with removable canopy. best of both worlds and the 84-85 ones have have solid front axle. good base to start and reasonably cheap to buy
Posted: Fri Mar 28, 2008 9:55 am
by 86-surf
Posted: Fri Mar 28, 2008 12:23 pm
by surf_tomo
Steve
Good advice Steve. Yeah I would recomend a AA check, have had a few done now and they are really thorough.
Tom.
Posted: Sun Mar 30, 2008 8:32 am
by Dick
Went and saw a 93 toyota d/c yesterday, almost brought it, however, there was only water in the Radiator, no radiator fluid, and the water was rusty with a slight taint of an oily look. The guy selling it said it was in the garage getting that fixed 26,000kms ago, so running an engine with no radatiator fluid for 26k, which probally was through last winter, im quite sure that is not good for it, hence we left it alone.
Anyway, on the topic of another ute, the navaras, other than the fact they are a bit sluggush, what are the motors like in them? Can they handle the high kms the hilux can. The reason I as is because of this:
http://www.trademe.co.nz/Browse/Listing.aspx?id=147472341Its a 98 Nissan with 400,000kms. Should we just forget about this track right now, or would it be worth pursueing it?
Posted: Sun Mar 30, 2008 8:04 pm
by SupraLux
Sounds like you're after champaign on a beer budget... go back and buy the Toy, water is an ok coolant, obviously not as good as glycol, but better than nothing in the rad at all
Tell them you want the engine professionally checked first if you're worried.
Steve
Posted: Mon Mar 31, 2008 7:34 am
by nstg8a
SupraLux wrote:Sounds like you're after champaign on a beer budget... go back and buy the Toy, water is an ok coolant, obviously not as good as glycol, but better than nothing in the rad at all
Steve
second that..... i hardly ever use glycol and ive never had a problem because of it.....
Posted: Mon Mar 31, 2008 7:42 am
by Dick
nstg8a wrote:SupraLux wrote:Sounds like you're after champaign on a beer budget... go back and buy the Toy, water is an ok coolant, obviously not as good as glycol, but better than nothing in the rad at all
Steve
Really...whoa... I have always been told not to have engines without antufreeze in them, due to cracking the head etc when the water freezes during winter.
The other side of the coin, we are just weighing up what else we can get for our 8 - 10g. For example, instead of a 93 Hilux, something like this
http://www.trademe.co.nz/Browse/Listing.aspx?id=146729531 may be more suited, for the amount of off-road driving my brother will be doin...Its a hard one all rite.
Posted: Mon Mar 31, 2008 8:17 am
by tweake
water only in a motor will cause the block to rust out from the inside. usually you don't notice it until it pinholes the bore. repairable if you can replace the liners. also it can eat out the water pump and with some motors cause electrolysis on the block/pump and it will eat the metal out.
a family member has just repaired a tractor thats had the same fate. low hours but pin holes in the bore and sweet f all left of the water pump impeller. also I've seen a motor where the block behind the pump was eaten out by cavation/electrolysis right through to the water jacket (meaning pump doesn't do jack and it overheats, one new block required). that was put down to never having the coolant changed.
Posted: Mon Mar 31, 2008 8:20 am
by Dick
tweake wrote:water only in a motor will cause the block to rust out from the inside. usually you don't notice it until it pinholes the bore. repairable if you can replace the liners. also it can eat out the water pump and with some motors cause electrolysis on the block/pump and it will eat the metal out.
Cheers for that.
by tweake
Dick wrote:Went and saw a 93 toyota d/c yesterday, almost brought it, however, there was only water in the Radiator, no radiator fluid, and the water was rusty with a slight taint of an oily look.
its stuffed. it takes a while for that rusty look to appear. its proberly starting to overheat, either cracked head or holed bore. avoid unless you can get it real cheap and replace the motor.
Posted: Mon Mar 31, 2008 8:22 am
by Dick
tweake wrote:Dick wrote:Went and saw a 93 toyota d/c yesterday, almost brought it, however, there was only water in the Radiator, no radiator fluid, and the water was rusty with a slight taint of an oily look.
Yeah the guy was wanting 9g for it, so we were not to keen cause of the radiator water thing.
Posted: Wed Apr 02, 2008 6:06 pm
by Steve_t647
For the difference in price unless you need the tray you could mount the bike across the back of a surf. I have a ute and 300,000 km and it is still going strong, the ute is a pain at times large no lockable boot etc but a bonus at others
Posted: Wed Apr 02, 2008 6:31 pm
by Sadam_Husain
Steve_t647 wrote: the ute is a pain at times large no lockable boot etc but a bonus at others
The problem with ute's is everybody always throws their empty beer cans on the back
Posted: Wed Apr 02, 2008 7:02 pm
by KiwiBacon
skid wrote:diesel not much cheaper and then you have to pay a $100 a year more for rego and road users etc etc
very tempting
Offroad you'd be using half the fuel with a diesel, onroad probably 1/3 less.
Of course some change in the pocket to repair a cracked toy diesel head is probably wise.
