ome shocks or monroe
For all Nissan related topics
gary_in_nz
Post by gary_in_nz »
hi, this could have gone in the shocks/drivetrain section... but anyway, i have 50mm lift springs in my swb safari and run the stock monroe shocks. trouble is i need longer ones for full articulation.
any ideas>
whats best bang for buck solution??
read somewhere on here that the ome shocks tend to heat up a bit if they are getting used?? also wondering how much a set of 4 is worth??
Jafa
Re: ome shocks or monroe
Post by Jafa »
What travel do you need?
021 273 9942
jafa@inspire.net.nz
gary_in_nz
i guess the standard plus 50- 75mm
Dak
Post by Dak »
Get a set of OME ones for a 50mm lift, I've been running a set for near on 5 years and they havn't let me down yet. Can't remember how much they were.
Cheers, Jeff.
gary_in_nz
hi, yeah got me a set of ome's on the way, shade over $700 for the 4, some nice softer ones too, cheers
doddzee
Is Doddgee
Post by doddzee »
gary_in_nz wrote:hi, yeah got me a set of ome's on the way, shade over $700 for the 4, some nice softer ones too, cheers
Did you get the LTR's? That alot of money for Standard OME's if they arent. You can get a set of 4 EFS for under $400 from 4wdbits. You can get adjustable 88 series konis for alot less than that too.
MWB V8 Safari Ute
Dak
Post by Dak »
?? $185 each for EFS ones from 4wdbits.
doddzee
Is Doddgee
Post by doddzee »
Dak wrote:?? $185 each for EFS ones from 4wdbits.
Assumed that was for pair. Either way $700 still sounds like alot to me for a set of shocks.
4 koni 88 series adjustbales cost me less than 600 and that was to suit 5 inch lift. They are a top quality shock.
MWB V8 Safari Ute
DaveM
Post by DaveM »
I'm having the same problem at the moment, I'm not paying $185ea for standard EFS shocks, OME L series are $150 odd each, but I will look into the Koni's again I think.
Doddzee, where did you get yours? They were for sale on TM all the time a while back, but haven't seen them advertised for some time now, looked through your old build up posts but couldn't spot where you got them, but I'm sure you mentioned it in there somewhere.
Dave
GQTROL
Post by GQTROL »
DaveM wrote:I'm having the same problem at the moment, I'm not paying $185ea for standard EFS shocks, OME L series are $150 odd each, but I will look into the Koni's again I think.
Dave
Not sure where Doddzee got his Koni's from, but I was dealing with Wayne Emmerson (021 221 9322) when I was looking to get some.
