Diff Breathers
RJ
Diff Breathers
Post by RJ »
Hi all,
As you do on a Friday I raced home to work out how to extend the Diff breathers on our 92 Pajero. The rear one looks easy enough, will probably just get new tube and run it up somewhere out of the way and pop a wee filter on to stop any nasties getting back down there. No Probs
Now the front Diff breather is a different story. It appears to be a small plastic stub fitting over some sort of small metal valve, or something, then well thats about it really. Has anyone extended the front diff breather on there Gen II pajero using the existing hole etc.
LOWDWN
Re: Diff Breathers
Post by LOWDWN »
i scoped it all out when my engine was out and it all runs to that brether, just extend that and your done 8) easy access
red-devil
Re: Diff Breathers
Post by red-devil »
i took off the front cover removed the water trap plastic thing. welded " Brazed" a new tube ant extended into engine by. time taken for whole job 2 hours
RJ
Re: Diff Breathers
Post by RJ »
LOWDWN wrote:i scoped it all out when my engine was out and it all runs to that brether, just extend that and your done 8) easy access
Hey Sam,
The front breather is a small stub on ours (some sort of non return valve), I think they changed the setup on your model and put a proper breather on the front diff. It seems to have s small plastic flange in there. I was hopeing not to weld anything on it but I guess we might be heading that way.
Rod
NJV6
Re: Diff Breathers
Post by NJV6 »
Yes, the early diffs had some sort of dopey arrangement. From about 94 on they had a proper breather that goes right up the guard. I think the easiest way would be to take the front cover off and drill and tap a tube.
RJ
Re: Diff Breathers
Post by RJ »
Cheers team
NJV6 wrote:Yes, the early diffs had some sort of dopey arrangement. From about 94 on they had a proper breather that goes right up the guard. I think the easiest way would be to take the front cover off and drill and tap a tube.
Yep I think your right NJV6. My only other thought was to get a metal version of the plastic barb that is in there at the moment. Will have to reconsider the options
Hhhhhhhhhhhhhhhhmmmmmmmmmmmmmm!!!
Return to “Mitsubishi”
