Will be on trademe in the next couple of days
Contact Mike on 021344769 if interested !
This toy kicks butt
As seen on 4wdtv
http://www.4wdtv.co.nz/node/434
Exo cage with tube doors
Bobbed rear end
Dents at no charge
Engine:
5M-GE EFI Supra
Transmission:
Hilux W56 5 speed with W58 bellhousing
Dual ultimate transfer cases, 4.7 Gears in second transfer case
Incredible 200:1 crawl ratio, 20 forward gears, 4 reverse
Low profile cross-member
Steering:
Cross Over Steer
Billet Steel Hi-Steer arms with Trail-Gear Rock Rods
IFS Steering Box
Axles
Locked Front with 30 Spline Cro-Moly Longfield SuperAxles
Wide Front conversion with IFS hub plus 25mm spacers
Rear leafs fitted up front for clearance and better approach angle
Rear locked and widened with 50mm wheel spacers
Disk brakes and Falcon leaf conversion on rear axle
Wheels
Two sets,
37MTR's on 15 X 8 steels
42 Super Swamper TSL's on 15 X 10 alloys
