the pump on my pajero is leeking desiel i can get hold of a real good 2nd hand one cheep the question is how hard are thay to fit ive been told thay need to be timed
how do u do that ?
leeking desiel pump
Re: leeking desiel pump
Its a bit like a dizzy on a petrol but you cant use a timing light you need a DTI that screws into the back of the pump.Its a bit cnfusing if you havent done it before I had to be shown 2 or 3 times before i got the gist of it. If you can get hold of the wright DTI and know how to use it and get the settings I should be able to tell you how to set the timing
Dion
Dion
