Any one wrecking a 4.2 deisel motor, I need a harmonic ballancer for a project I am under taking.
Also are the later model harmonic ballancer's the same thickness as the earler ones, As the thickness of a 89 GQ is 20mm
and for what I want the thicker the better.
Graham
GQ harmonic ballancer Wanted
Nissan Safari SWB Auto ,50mm suspension Lift , 50mm body lift, 12000lbs winch,
33x12.5x15 Perilli scorpion muds
