the idea struck me instead of turbing my 5l toymota, why not stick a supercharger on it
Your thoughts?
Dak wrote:A guy from CCVC, Ron Wodham?, I think was his name, used to have a LWB Safari that he bought brand new. He had it fitted with a supercharger pretty much from day one I think, it used to go bloody well. Unfortunatly it was written off. Dodzee on here bought the wreck I think, come to think of it, Dodzee, where did that engine go?
rayndeb wrote:if my turbo s@#t itself i would s charge it..I like the idea of boost from idle but they do lose breath higher in the rev range..Check out sprintex they have bolt on kits ..Just sit down when you get a price
DBWRacing wrote:Dodzee, do you have any info on what had been done the SC diesel you had, year and engine type, electronic injection or mech, HP and torque figures?
tweake wrote:there was a few good posts on this on outerlimits.
they had good power down low but tended to loose out on the top end and also drank more gas. making the brakets and getting it to fit is a bit of a pain too.
turbo is generally easier and you either gain economy or get more power for the same amount of fuel used. however it lacks that nice low down power the SC gives and the SC has no lag or wating to get the motor loaded up enough for turbo to make boost.
if your really keen why not both ??
tho sizing can be a pain. they don't always work well with a simple wastegate type actuator. boost is a critcal factor, but you also have to watch backpressure and turbo rpm. ie it can create a large amount of backpressure and spin the turbo too fast trying to produce boost at low rpm.KiwiBacon wrote:Or a variable vane turbo, just use a pressure actuator.
