low down rattle
Posted: Sun Apr 06, 2008 9:39 pm
by long
I get a rattel in my TD 2.7 that sounds like pinking in a petrol motor and it also seams to be running on 3 cyls when it dose this only happins at low RPM though any ideas out there im thinking it mite be the filter in the top of the injector pump getting blocked leaning out the diesel folw ????
Re: low down rattle
Posted: Sun Apr 06, 2008 10:46 pm
by mudhaw
Does it blow any smoke when it happens, if so what colour. Does it happen when its hot or cold or all the time. Have you just filled up with fuel ?. Dose it use any water. May seem like simple and or dumb questions but they can all help to solve the problem. Alot of problems can be solved with these simple questions. Also make sure your front pully isnt lose, came across that problem last week made a strange rattle and seemed gutlles.
Re: low down rattle
Posted: Mon Apr 07, 2008 7:01 am
by long
No to all the above including the pully and it still has usal amount of power
Re: low down rattle
Posted: Mon Apr 07, 2008 4:08 pm
by mudhaw
Try checking the valve clerances and may be a compression test.
Re: low down rattle
Posted: Mon Apr 07, 2008 5:22 pm
by Heath
Is an exhaust valve sticking?
Re: low down rattle
Posted: Mon Apr 07, 2008 7:23 pm
by long
I have been thinking about this while at work today im woundering if the injection pump is out of timeing if it was would it cause this to happin ????
Re: low down rattle
Posted: Thu Apr 17, 2008 6:37 pm
by Dak
Could also be a sticky injector.
Re: low down rattle
Posted: Thu Apr 17, 2008 6:47 pm
by long
it seams to happin after driveing for a while more than short trips it sorta sounds like a cam berring that has gone in an ally head and yes it dose seam to be comeing from the front of the motor.
The noise sounds like a very loud clacking but ilke i say it dosnt happin all the time.
Re: low down rattle
Posted: Wed May 07, 2008 6:44 pm
by long
Ive put new injecters into my terrano it had 2 that were leaking quite bad the motor seams to be running a lot smother as well.
BUT I STILL HAVE THE RATTLE ive been told that the EC valve mite be shot has anyone had to replace theres if so where is it found ?
Re: low down rattle
Posted: Wed May 07, 2008 7:32 pm
by mudhaw
Usualy found on the inlet manifold, the best way to fix it is to block it of. Replace the gasket with a plate of panel steel and dont put the hole in the middle, and block off the vacume hose. Makes it run better and stops the soot build up in the inlet manifold.
Re: low down rattle
Posted: Tue May 20, 2008 7:19 am
by long
Blocked off the ER valve on the weekend what a DIFFERANCE it has made to it and no more low down rattle wahoooooooooooooo
Re: low down rattle
Posted: Tue May 20, 2008 10:02 am
by tweake
check the butterfly on the inlet pipes. if it operates while motor is going (with bit of throttle) then you will need to disable it.
Re: low down rattle
Posted: Tue May 20, 2008 6:14 pm
by mudhaw
Thats good news
EGR systems on deisles seem to cause more harm than good
Re: low down rattle
Posted: Tue May 20, 2008 6:18 pm
by long
Yeh not only blocked off the ER valve but also blocked off vacum line as well so nothing works there now
and i have more power as well so it was worth doing
