Removing the starter moter on a Surf
dazza85
Post by dazza85 »
What are the tips and things to watch out for when trying to remove the starter on a '91 2.4l Surf
It's a LN130 body, automatic and still has the EGR system in place ( but not for long )
I have located the bottom bolt but can't find the others - How many am I looking for ??
Does anybody have one of these motors sitting on the ground that they could take a photo of ??
Any help would be apreicated
86-surf
Re: Removing the starter moter on a Surf
Post by 86-surf »
cant take a picture but the 2.4 we took out of a toyota hiace, Had two bolts one on the bottem and one on the top, and that was all that was holding it on. hope that helps?
dazza85
Post by dazza85 »
86-surf wrote:cant take a picture [\qoute] what no camera on your phone ??
but the 2.4 we took out of a toyota hiace, Had two bolts one on the bottom and one on the top, and that was all that was holding it on. hope that helps?
That a great start ... Thanks Jase
skilly6
Post by skilly6 »
the starter will have 2 bolts holding it to the bellhousing one self taped into bell housing one nut and bolt, 1 nut that holds main power feed on the top of it under a rubber cap and a plug for activating the starter wich is right next 2 it both seen from on top this is a prick of a task as theres no room to get yr hands in! then its a tricky bit getn out of the engen bay
it takes 2 mins on my body lifted ln106 easy as nothn like goin it on a surf
