Just wondering if anyone would know of a good paint to use for painting steel rims?
Dick
Rim Paint - What to use?
Go Hard or Go Home
- skid
- Tyre Man
Re: Rim Paint - What to use?
powdercoat.
I took mine up to competition coatings in the industrial area, can't remember, but I think I paid about $40 per rim
- niblik
- Sausage Shack
absolutely no use, but......
just make sure the rims are prepared well prior to the powder coatin as i've heard stories/rumours of water gettin under the coatin due to ill prep or the porous nature of the powder coating and creating a layer of rust between the rim and the coating.. this then led to the coatin peelin/chippin off..
if a normal styles paint is used and is scratched off, then a quick application over the scratched/damaged area is too easy and done where and when needed and can be performed by any johnny lunchpail..
whichever way ya go, good luck fella..
the problem area is where the center meets the rim its hard to get the powder coat/paint in there
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
