Hilux diff locators
Heath
Hilux diff locators
Post by Heath »
Hey guys,
The diff locator on my lux is a little short (after the lift) and pulls real hard on the front diff, rolling it forward (bump steer anyone).
So i splashed out on an adjustable one to hopefully fix this problem.
Question is how much tension should I pre load it with when fitting?
Should it just be done up snug to fit the diff location when stationary and on a flat level ground or should it be under tension?
Heath
Jafa
Post by Jafa »
Hi Heath,
Just adjust it until its the right length at ride height, ie no preload
021 273 9942
jafa@inspire.net.nz
Return to “Tool Shed”
