Page 1 of 2
Is my clutch stuffed..?
Posted: Sat Apr 26, 2008 11:28 pm
by Beer_Cruiser
went for a drive round the south coast today after giving my mate a small tug out of the sand i noticed a horrible grawnching tapping noise. after a bit of investigation found it was coming from the clutch.noise stops when i put my foot on the clutch.theres no noise when driving or under load, it still goes into gear and clutch still works fine. has anyone any idea what it could be? is my clutch stuffed or is it something much much worse than that?
thanks for your advice in advance
Malcolm
Re: Is my clutch stuffed..?
Posted: Sat Apr 26, 2008 11:50 pm
by Dace
Beer_Cruiser wrote:went for a drive round the south coast today after giving my mate a small tug out of the sand i noticed a horrible grawnching tapping noise. after a bit of investigation found it was coming from the clutch.noise stops when i put my foot on the clutch.theres no noise when driving or under load, it still goes into gear and clutch still works fine. has anyone any idea what it could be? is my clutch stuffed or is it something much much worse than that?
Malcolm
so when ya push the clutch in, the noise goes away?
cause if the noise is there when ya push it in, could be the release bearing or maybe the spigot.
Posted: Sat Apr 26, 2008 11:58 pm
by Sadam_Husain
If your lucky it might just be some of that coarse sand in your clutch and it'll eventually grind itself up and it'll go away or otherwise like Dave said it may be the release bearing or spiggot bearing which means you'll have to drop the gearbox
Posted: Sun Apr 27, 2008 12:00 am
by Beer_Cruiser
DBWRacing wrote:Beer_Cruiser wrote:went for a drive round the south coast today after giving my mate a small tug out of the sand i noticed a horrible grawnching tapping noise. after a bit of investigation found it was coming from the clutch.noise stops when i put my foot on the clutch.theres no noise when driving or under load, it still goes into gear and clutch still works fine. has anyone any idea what it could be? is my clutch stuffed or is it something much much worse than that?
Malcolm
Yep noise not there when I push it in . A mate said some thing about release bearing. Do I have to fix right away or is this some thing I can wait untill I can get some money
Posted: Sun Apr 27, 2008 12:04 am
by Beer_Cruiser
Sadam_Husain wrote:If your lucky it might just be some of that coarse sand in your clutch and it'll eventually grind itself up and it'll go away or otherwise like Dave said it may be the release bearing or spiggot bearing which means you'll have to drop the gearbox
It sounds a lot worse than sand.
Posted: Sun Apr 27, 2008 8:04 am
by Cloggy_NZ
You are not just missing the spring which pulls the clutch release fork forwards towards the slave cylinder?
Just thinking that without this spring the release bearing and clutch fork are possibly free to move and "dance" around when there is no load on them i.e. when you are not pushing on the clutch. Could possibly create some funny noises.
If not and you suspect the release bearing and need some time to save a few bob, I would pull the rubber boot away from the clutch fork (assuming your model Cruiser still has this set-up) and get in there with a can of CRC with one of them extension squirter tubes on it. Give the release bearing a good soaking. It may just work. Some may frown on this practice for fear of contaminating the clutch linings. The way I see it is the clutch or some part of it is stuffed anyway. If you can buy yourself a little time doing this all good and well. When you do eventually pull the gearbox to replace the offending parts it is false economy not to replace everything all at once anyway. You will need to buy a new clutch plate, pressure plate and release bearing.
Posted: Sun Apr 27, 2008 10:34 am
by Beer_Cruiser
Cloggy_NZ wrote:You are not just missing the spring which pulls the clutch release fork forwards towards the slave cylinder?
Thanks mate am going to have alook now
Posted: Sun Apr 27, 2008 12:48 pm
by Beer_Cruiser
Its not looking so good. I went to see one of Wellingtons better mechanical brains (Turoa). We pulled the Flywheel cover plate off. The noise seams to be in the flywheel. With the cover off I could move the FW about 5mm each way
Looks like Im droping trans out this week to see what I can find
Posted: Sun Apr 27, 2008 1:07 pm
by cool__bananas
just drive it untill it stops because if you cant see whats wrong it means there is nothing wrong
Posted: Sun Apr 27, 2008 1:30 pm
by TJ
cool__bananas wrote:just drive it untill it stops because if you cant see whats wrong it means there is nothing wrong
But he can "hear" that something is wrong. Driving for long without identifying whats wrong can lead to a bigger mess, particularly if whatever it is thats "broken" gives up the ghost and destroys neighbouring components.
Posted: Sun Apr 27, 2008 4:53 pm
by Cloggy_NZ
Beer_Cruiser wrote: With the cover off I could move the FW about 5mm each way
When you are moving the flywheel backwards and forwards (I assume it is able to be moved this way and not sideways
) does the cranksnout move the same amount?
If so, it is not the gearbox you need to drop. Sounds like the thrustbearings on the crankshaft are shot.
Good news is that these can usually be replaced with the engine and gearbox in place. Drop the sump and do one bearing at a time.
Fiddely but possible and a shytload less work than pulling the engine.
And if the cranksnout doesn't move when you move the flywheel, I wouldn't even start the engine anymore. Because then the flywheel is actually somehow loose from the crankshaft and if/when it lets go altogether it can make a big mess of things.
Posted: Sun Apr 27, 2008 6:38 pm
by skid
Posted: Sun Apr 27, 2008 6:54 pm
by Jerry
its obviously faulty, go and Visit SIG and pull the clutch apart, may as well pull that 3b out as well and drop in SADDAM's new 350 as well ....
his truck seems to go fine with the 305
, Saddam said its ok
Posted: Sun Apr 27, 2008 6:56 pm
by turoa
Jerry wrote: pull that 3b out
oooh. you're in for a hiding now. calling beer_cruisers motor a 3b
Posted: Sun Apr 27, 2008 7:06 pm
by Jerry
oops do I mean 3f?
Posted: Sun Apr 27, 2008 7:35 pm
by Beer_Cruiser
Im still not sure exactly what my problem is yet(apart from a few of the obvious ie no money shit job a beer fridge that is starting to look a bit bare)so my plan at the moment is to take it to MP Autoparts tomorrow and get them to have a look. Hopefully they can give me some idea. I think its probably going to involve a new Cluch so tomorrow night Im hosting a PULL THE CLUTCH OUT PARTY at 19 Nicolaus st Upper Hutt (All Cutt concrete cutters yard). Beer and food will be provided!!! I do need to get hold of a trolley jack . Can anyone lend me one for a few days. Work finishes about 4 so any time after that
Thanks Malcolm
Posted: Sun Apr 27, 2008 8:04 pm
by Sadam_Husain
Beer_Cruiser wrote:so my plan at the moment is to take it to MP Autoparts tomorrow and get them to have a look. Hopefully they can give me some idea.
I dealt with them(I think the guys name was Greg) and they rebuilt my pressure plate and modified my carrier etc when I put my chev in, he was an awesome dude who knew a lot about clutches and I'd definately recommend them
Posted: Sun Apr 27, 2008 9:08 pm
by SV1K
I got a jack here you can use dude, can't help at the start sorry, might come up after 6pm though if you are still there.. will txt first....
Posted: Sun Apr 27, 2008 9:20 pm
by gazza
have 3 ton jack sitting in back of truck can drop over during the day (2moro) if it helps. do you have axle stands ect????? answer here or text me on 0211 310045 P.S bloody landlord wants his homer bottle opener back grrrrrrr driving me nuts
Posted: Sun Apr 27, 2008 9:30 pm
by Beer_Cruiser
would love to borrow the jack...i have axle stands thanks. we went to the batch on weekend and the mrs had a look for the homer bottle opener but couldnt find it anywhere...sorry mate. there is a deck chair there..is that yours, also a grey polar fleece???
Posted: Sun Apr 27, 2008 9:33 pm
by SV1K
Beer_Cruiser wrote:also a grey polar fleece???
Is it a canterbury polar fleece? if so I think is the one that I am missing....
Posted: Sun Apr 27, 2008 9:35 pm
by Beer_Cruiser
no worries you can pick it up from allcutt tomorrow after 4......
Posted: Sun Apr 27, 2008 9:40 pm
by gazza
oh bugger was a present to him from someone lol errrrr will think up some bullshit to cover my arse i,ll drop it over early afternoon i presume to the address above in upper hutt???? could be wrong but doubt will be crank shaft bearings as you would of prob noticed noise b4 unless they let go which would be un usual,,, hopefully something less of a prob just thrown a clutch in a sj 413 was less than 2 hrs doing it on the deck ,,,,,,, yes chairs mine
by gazza
In fact i could just blame jerry for losing it
Posted: Sun Apr 27, 2008 9:45 pm
by turoa
I think the flywheel bolts have some loose and then ovalled out the holes
Posted: Sun Apr 27, 2008 9:47 pm
by gazza
that sounds more likely do you have another flywheel????? plus are you gonna change thrust/pressure/ clutch plate while its out
Posted: Sun Apr 27, 2008 9:49 pm
by Beer_Cruiser
gazza wrote:oh bugger was a present to him from someone lol errrrr will think up some bullshit to cover my arse i,ll drop it over early afternoon i presume to the address above in upper hutt???? could be wrong but doubt will be crank shaft bearings as you would of prob noticed noise b4 unless they let go which would be un usual,,, hopefully something less of a prob just thrown a clutch in a sj 413 was less than 2 hrs doing it on the deck ,,,,,,, yes chairs mine
yep its the address I mentioned in upper hutt..its closer to trentham. I wont be there until after 4 but there will be someone around.
Sorry about the homer bottle opener..it was there at easter when we were last there...but we are not the only key holders..someones kid may have taken it home...will ask around but dont hold your breath! sorry mate!
Posted: Sun Apr 27, 2008 9:51 pm
by Beer_Cruiser
turoa wrote:I think the flywheel bolts have some loose and then ovalled out the holes
so do you think I am going to need a flywheel as well as clutch pressure plate and thrust bearing???
Posted: Sun Apr 27, 2008 9:52 pm
by gazza
Posted: Sun Apr 27, 2008 9:53 pm
by Sadam_Husain
Is the 2F flywheel still on Curlys old engine? I compared the 2F and 3F flywheels when I pulled my old engine out and the 2F is a thicker and heavier flywheel but should still fit.... and probably helps give a bit of torque to keep those 35's turning
