looking at it for some duck shooting, any thoughts.
winchester 1200 ranger
- moonhopper
hi guys has anyone had much to do with a winchester 1200 ranger shotgun its a pump action 3 in the tube.
Re: Winchester 1200 ranger
Winchester pumps are very reliable, pumps are not the easiest to get use to if you have had no practice with them. You have to remember to pump them. They are very safe because you can leave the breach half pumped and when you want to fire, finish off the pump stroke and pull the trigger. Make sure it's STEEL SHOT compatible, no tighter than Modified (1/2) CHOKE.
Good Hunting & Keep Safe.
I'M OFF TO THE MIA MIA FOR FIVE DAYS,
FITZY.
FITZY.
- curly12
Re: winchester 1200 ranger
And size does matter
Go for a decent length barrell and also check that it will take the longer length cartridges. Mine would fire them but would have problems ejecting some brands.
- moonhopper
Thanks guys
just considering some 3" kent fast steel shot for it 1550fps , or should i stick with the 2 3/4"
Nothing wrong with 2 3/4" shells, I would like to pattern those 1550fps shells, with some of that fast ammo it blows the pattern to bits. The other thing when measuring fps is where is the speed taken, wonder what it is doing at 10 meters ? .
Get a shell that suits you and the shotty. My Mate and shooting partner imports HULL ammunition, so any questions get in touch. I will be away from the computer for a week.
DON'T HURT THOSE LITTLE DUCKS,
FITZY.
FITZY.
