15x8 Range Rover Rim Needed urgently!
muddymatt
Post by muddymatt »
Hi due to being slightly shafted by another ORE member who will remain nameless unless he fails in his word to contact me and arrange some money back I need at least 1 more white 8 spoke rim.
I have three with one offset and one genuine Mangels brand with a different offset :x
Does any one have any odd 8 spokes with a Rover stud pattern? If so please measure your offset and hopefully it will match either of the ones I have.
Best case is another mangels so I have two with 1 offset and two with the other. Then I can run the big offsets on the front for more steering lock and the smallers on the rear.
Muddymatt
Edit - Still need a rim.........
muddymatt
Re: 15x8 Range Rover Rim Needed urgently!
Post by muddymatt »
Still needed ASAP - someone must have an old 15X8 or two spare....
mercutio
Post by mercutio »
i happen to have 4 of them 3 of one offset and 1 of another
whereabouts are you
i could get my old man to check the offset if you want
my 4wd is not a truck
muddymatt
Post by muddymatt »
mercutio wrote:i happen to have 4 of them 3 of one offset and 1 of another
whereabouts are you
Yes please!!!! Check the offset and PM me. From memory mine are either 122mm or 102mm measured from inside rim to bolt face but I can check tommorow.
Cheers Matt
