hey any one remember the bolt lenghts for a 88 nissan terrano to suit a 5omm body lift..
thanks
terrano 2" body lift bolt lenghts
Re: terrano 2" body lift bolt lenghts
stainless wrote:hey any one remember the bolt lenghts for a 88 nissan terrano to suit a 5omm body lift..
thanks
I cant remember what length mine were when I did the lift on my 95, but you can easily remove one of the two front ones, measure them and get some new ones that are 50mm longer.
Remember these are fine pitch threads and the two rear bolts are 12mm, not 10mm diameter like the rest.
Ph 0212078472
Ph 0212078472
yip thats supper but i dont have one yet...
somone wonts me to do a lift on there truck next weekend and it would be nice to have the bolts ready to go so i dont have to rush into town to get them.. so the rear 2 bolts are m12x1.25 and all the rest are ok with m10x1.5 same as safari..???
Dont quote me but I think the pitch was the same on both sizes. I will have a look later.
Ph 0212078472
Ph 0212078472
hey pete
thanks but the pitch of the front bolts has no consequence as they will be replaced with new high tensile bolts and nyloc nuts!
as stated in my first post its the lenght that i have interest in.... either the stock lenght or the lenght to suit a 50mm body lift.
also i am making some ifs idler arm supports do you think anyone would be keen (same as the calmini ones)???
thanks steve
thanks steve
stainless wrote:hey pete
thanks steve
There are two pairs of bolts that you may not be able to access the origonal nuts, the rear ones and from memory the 2nd from the front ones. These two pairs have the nuts under the floor skin. I was able to apply gentle pressure to mine to undo them without any issues.
Somewhere I have a walk through of the job in .txt form that I will look for.
You have to loosen some vital parts first.
As for the idler arm braces, im sure you will find interest from a couple on here.I managed to score a Calmini one from a local shop at cost, so I was happy there.
Search for my post on my body lift, there was a small mod I had to do to the Calmini one to make it fit, but if you are custom making them, you will sus it yourself ok.
Ph 0212078472
Ph 0212078472
