Knob on dashboard?
For all Nissan related topics
marbiol
Stropper
Knob on dashboard?
Post by marbiol »
I've just got a 1991 Terrano R3M TD27 and there's a knob on the dash below the steering wheel with a picture of an engine on it. It only has and in and an out position - nothing in between.
It's the middle one in the pic - the toggle switch is for the spots.
Does anyone have any idea what it does?
DaveM
Re: Knob on dashboard?
Post by DaveM »
I thought it was for idle? Should be able to wind it in and out to set?
Big-AL
Post by Big-AL »
i thought it was a hand throttle. like an accelerator, but for your hand instead of your foot :P
marbiol
Stropper
Post by marbiol »
Just seems to click in and out (pull/push). There's a definite click and two points it sits at...
DaveM
Post by DaveM »
Have you tried it with the engine running? Might be broken?
tweake
Post by tweake »
check what it connects to ;)
i don't know with nissan but i think i've sen one similar and it was a shutoff for intake air ie close a low mounted air intake for water crossings.
Smurf
Post by Smurf »
If you pull it out while you have the throttle pedal depressed does it lock your throttle in place?
kiwipete
Post by kiwipete »
Its a hand throttle!
Ph 0212078472
surf_tomo
Post by surf_tomo »
Its a throttle/ idle switch. I had one on the surf except it screwed in and out, Good on cold mornings.
Flash2004
Post by Flash2004 »
Terranos often have a knob on the dashboard which is not normally much use, mainly to match the knob behind the steering wheel, and the truck itself. :lol:
DaveM
Post by DaveM »
Flash2004 wrote:Terranos often have a knob on the dashboard which is not normally much use, mainly to match the knob behind the steering wheel, and the truck itself. :lol:
Coming from the driver of an inverted hedgehog? :lol:
Flash2004
Post by Flash2004 »
That's a new one Dave? Never heard that before, but it might be quite good, do you mean the Jeep?
DaveM
Post by DaveM »
Flash2004 wrote:That's a new one Dave? Never heard that before, but it might be quite good, do you mean the Jeep?
The pricks are on the inside........light hearted comment of course, so not to be taken the wrong way ( I like Jeeps :oops: )
muskie
Post by muskie »
my 94 terrano clicks out about three clicks raising the engine speed the further out it goes, i use it a bit like a choke the first start of the day, my 1991 terrano did exactly the same and used it as a hand throttle.
Flash2004
Post by Flash2004 »
What a beauty! I'll pinch it of course.
marbiol
Stropper
Post by marbiol »
Yep - definitely the idle speed adjuster... Had to pull it a little harder than I was before to make it do anything (was being too careful before)...
Flash2004
Post by Flash2004 »
marbiol wrote:Yep - definitely the idle speed adjuster... Had to pull it a little harder than I was before to make it do anything (was being too careful before)...
They always work better when you use the accelerator to get the engine speed to where you want it, then pull the knob out to hold it there.
kiwipete
Post by kiwipete »
If yours is anything like mine, the first 3 or 4 notches are so worn that it won't hold. I'm going to look for a replacement one soon which is a wind up type.
Ph 0212078472
Bubba
Post by Bubba »
Be careful using hand throttles to much, I had issues with the idle on my Cruiser and countered it by using the hand throttle, until I needed to brake in a hurry, with the throttle pushing from the rear and me pushing the brakes on the front it had a tendency to lock up the front wheels and a skidding swerving fat Cruiser bearing down on a stationary Mazda 323 is not a pleasant beast.
If you pull it out make sure you put it back in before it gets you into trouble, also a good mantra for life :wink:
Benjamin Franklin
Flash2004
Post by Flash2004 »
Bubba wrote:Be careful using hand throttles to much, I had issues with the idle on my Cruiser and countered it by using the hand throttle, until I needed to brake in a hurry, with the throttle pushing from the rear and me pushing the brakes on the front it had a tendency to lock up the front wheels and a skidding swerving fat Cruiser bearing down on a stationary Mazda 323 is not a pleasant beast.
A better mantra for life would be to pull it out before its too late?
celtic1522
Stropper
Post by celtic1522 »
It is to add the supercharger and nos when you need it! Just wait till ya in the crap, then hold on to the knob and pull! That 2.7 will seem as if it has another four cyliners added to it!!! Oh, but be sure to wear that neck brace to stop whiplash...... and have a TUI, yea right!
