suspension fj40
suspension fj40
Gidday, I have an Fj40, Wanna get new leafs with a bit of a lift. Wondering if Front leaf reversal shackle kits are available here? A company in usa specialises in Fj40 mods, but way to $$ to get it shipped over.
Re: suspension fj40
I'm pretty sure Niblik did a front shackel reversal on this 40 hes building, theres about 26 pages to sift through on his build thread to find it
Bj40 build thread press here
- MNC
Re: suspension fj40
Can carefully grind off both mounts and switch them round. Did that and pushed out about 40mm to match perches on 60 series diff housing.
A cheap and nasty is to just weld your front swinging shackles so are fixed and add swinging shackles to the rear. Will give you some lift to.
- niblik
- Sausage Shack
Re: suspension fj40
mnc you rough bastard!!!
easy to do bro, cut em off carefully and switch em to the rear.. gotta use a bit of grunt to knock out the rivets too.. stubborn biatch's!
