land rover s2a v8 swb for sale
gonfellon
Post by gonfellon »
got this landie for sale, Its got a p6 rover v8 10.5-1 compression ratio fitted with army v8 gearbox.30x9.5x15 bfg a/t on white steel rims.Needs a paint so ideal at moment to see condition of panel work .chassis in good clean order apart from rear where the toe bar goes has slight rust coming through but no rust anywhere else.has bucket seats and it looks like the interior is out of a mack truck.ie red with bulldog stamped into it.Roll cage on the back looks sound and is bolted onto the chassis.reg is on hold..$1500.00 if anyone is interested
gary_in_nz
Re: land rover s2a v8 swb for sale
Post by gary_in_nz »
hey, is it a certified conversion?? what sort of brakes and running gear?? is the gear box the 4 speed lt95?? cheers
Big-AL
Post by Big-AL »
where are u located?
gonfellon
Post by gonfellon »
hi i live in between foxton and shannon on the foxton-shannon road ,the landie is on front yard.
gonfellon
Post by gonfellon »
the gearbox is v8 army landie 4 speed.i've just got the truck two weeks ago ,so havent had a good look yet.the diff heads looks like they are army diff heads with strenghting rear diff i think they are 4.7 ratio ,the swivals look bigger than my rangies ones.the beam axles look stronger and bigger than the s3 i swapped for it.it does have a plate in the engine bay which isnt standard that has been stamped with s2b and v8 engine number and another code .i will go today and find out at the ltca if it is certified .it looks like it has been modified by a engineer
