Vacuum pump on an alternator
Posted: Wed May 07, 2008 5:39 pm
by kiwipete
Hi all.
I am thinking about upgrading the Alternator on my 95 Terrano to something around the 110A plus area, but mine has the vacuum pump attached to it.
Are all vacuum pumps the same, or do I need to look for a specific one?
I have seen a few Toyota alternators on trademe with the vacuum pump at a reasonable price.
And for those who are going to suggest that I simply add an extra alternator, I don't have room as my AC air compressor is going in the only spare space soon.
Re: Vacuum pump on an alternator
Posted: Wed May 07, 2008 6:21 pm
by rayndeb
cant they just modify your original
Posted: Wed May 07, 2008 9:02 pm
by kiwipete
I think re-winding an alternator would be somewhat expensive. I want to tackle this on a budget that is tighter than a fishes ass! :wink: So if it is possible to use just any old Alt with a vaccy pump on it, then im home n hosed so to speak.
Posted: Wed May 07, 2008 9:06 pm
by KiwiBacon
All vacuum pumps are pretty much the same.
What high amperage one have you found? About 4 years ago I had mine replaced, cost about $800 and 70 amp was all I got.
Mind you, 70 amp is plenty for my rig at the moment.
Posted: Wed May 07, 2008 10:12 pm
by kiwipete
Im just looking at my options at the moment, the vaccy pump is the issue. I want around 110 amps as I will be doing a 2nd battery and run too many accessories for one battery, including my winch.
Posted: Thu May 08, 2008 1:47 pm
by Steve_t647
Try find a Tacoma T100 alternator (the same size and configuration as us) but with 130A well that is what they are using in the US and it has the vac pump on it. If you can find out what else they went into you could get one here.
Good Luck
Posted: Thu May 08, 2008 6:31 pm
by rayndeb
try looking in aus web sites they seem to have heaps of elecs in their trucks.. dual bats and even triple bats surely they have to beef up their alts for that stuff
Posted: Thu May 08, 2008 9:28 pm
by kiwipete
Steve_t647 wrote:Try find a Tacoma T100 alternator (the same size and configuration as us) but with 130A well that is what they are using in the US and it has the vac pump on it. If you can find out what else they went into you could get one here.
Good Luck
Thanks, I have also heard of a "Nissan Quest" in the US, (110A?), but have no idea what they are or what they look like.
Posted: Mon May 19, 2008 8:16 pm
by Moriarty
Why the desire for a huge output alternator?
Surely the big batteries are there to handle those loads, the alternator is only to recharge the batteries.
Ok, the running lights etc are 'supposed" to be driven by the Alt, that Batt is there. initially, to start the beast.
is it possible to take the vac pump off a dead alt, and mount THAT smaller gizmo elswhere, and then you can run a much cheaper ND, delco or whatever alt?
Sure, you say the a/c pump takes up the avail space, but look at the size of the dismounted vac pump? must go to the auto-elec tomorrow, he will have a dead one that I can have to look at.
Reporting back on this in a few days.........
Posted: Tue May 20, 2008 9:53 pm
by kiwipete
Mori who? wrote:Why the desire for a huge output alternator?
Because I want to go for dual batteries, one being the Master for the engine and associated electrics, and the other for my accessories. These being, driving lights, computer, head unit with power amp, gps, winch, LCD screen, PRS radio, etc etc.
wot that same fella above wrote:Surely the big batteries are there to handle those loads, the alternator is only to recharge the batteries.
A bigger Alt will charge things back up faster than the puny 60A one thats stock, wont it?
more quoting wrote:is it possible to take the vac pump off a dead alt, and mount THAT smaller gizmo elswhere, and then you can run a much cheaper ND, delco or whatever alt?
The vac pump is part of the alternator, I dont think it is as simple as that to mount it elsewhere like you suggest.
last quote wrote:Reporting back on this in a few days.........
I eagerly await your report.
Posted: Sun May 25, 2008 5:00 pm
by 4wdnuts
hi pete
try give kaiapoi auto electric a call. they are good guys in there. they may be able to rewind your original alternator for less than what you may think.
Posted: Sun May 25, 2008 10:54 pm
by kiwipete
Thanks, i'll ring them sometime.
Posted: Tue May 27, 2008 9:18 pm
by Moriarty
Ok guys, as promised, went and did the homework re vac pumps and alternators
it CAN be done.
all you need to do is some very close tolerance machining. :P :P
basically.
vac P/p has a mains supply of oil and needs an oil return to sump. thats cool, you will already HAVE that.
BUT
vac P/p does NOT have bearings. It relies on the TWO bearings in the ALT to keep alignment.
ergo, to make a stand-alone vac pump you will need to make a plate to mount the vac P/p, with a shaft in two brigs, a spline to drive the vac P/p and a pulley or similar for drive off the fan belt(s)
As I said, it IS possible, after all, ALL things are possible, but I am afraid its just NOT cost effective.
Well, if you have the tools, and the skills and time, it DOES become practicable, but NOT if you had to pay for it.
Sorry..... Bob
Posted: Tue May 27, 2008 9:24 pm
by Heath
Be easier to rig a elec air pumpin reverse (sucking from a tank to create a patrtial vacuum) with a vacuum switch to turn it off, non return valve and use that as a supply for the brake booster/ clutch / whatever or rig a line to the intake manifold with a one way valve.
But of course I am only surmising (guessing) and dont really know anything about vac systems.
Heath
Posted: Tue May 27, 2008 9:51 pm
by Moriarty
Heath wrote:Be easier to rig a elec air pumpin reverse (sucking from a tank to create a patrtial vacuum) with a vacuum switch to turn it off, non return valve and use that as a supply for the brake booster/ clutch / whatever or rig a line to the intake manifold with a one way valve.
Heath
nah heath, that why a vac P/p, diesels dont have much in the way of intake manifold neg pressure.
Thats WHY they haff vac P/ps
elec vac P/p will die cos it MUST run continuous.
Best idee (Most practicable) is to buy modern diesel with vac P/p built into engine block and a standard alt.
